Datasheet MSS5131 (Coilcraft) Manufacturer Coilcraft Description Shielded Power Inductors Pages / Page 2 / 1 — Shielded Power Inductors – MSS5131. Designer’s Kit C362. Core material. … File Format / Size PDF / 320 Kb Document Language English
Shielded Power Inductors – MSS5131. Designer’s Kit C362. Core material. Core and winding loss. Terminations. Weight
Model Line for this Datasheet Text Version of Document Web Sample Tools & Support page & buy software & FAQ Document 642-1Shielded Power Inductors – MSS5131 AEC • 5.1 × 5.1 mm footprint; 3.1mm high shielded inductors Q200 85 + °C • Low DCR and excellent current handlingDesigner’s Kit C362 contains 3 of each valueCore material FerriteCore and winding loss See www.coilcraft.com/corelossTerminations RoHS compliant matte tin over nickel over phos bronze (current production) or gold over nickel over phos bronze (prior production). Other terminations available at additional cost.Weight 0.20 – 0.24 gAmbient temperature –40°C to +85°C with (40°C rise) Irms current.Maximum part temperature +125°C (ambient + temp rise). Derating.Storage temperature Component: –40°C to +125°C. Tape and reel packaging: –40°C to +80°CResistance to soldering heat Max three 40 second reflows at +260°C, parts cooled to room temperature between cyclesMoisture Sensitivity Level (MSL) 1 (unlimited floor life at <30°C / 85% relative humidity)Packaging 600/7″ reel, 2500/13″ reel; Plastic tape: 12 mm wide, 0.35 mm thick, 8 mm pocket spacing, 3.25 mm pocket depthPCB washing Tested to MIL-STD-202 Method 215 plus an additional aqueous wash. See Doc787_PCB_Washing.pdf. DCR SRF Isat (A) 4Irms (A) 5 1. Please specifytermination andpackaging codes: Inductance 2max typ 310% 20% 30% 20°C 40°C Part number 1 ±20% (µH) (Ohms) (MHz) drop drop drop rise rise MSS5131-394MLC Termination: L = RoHS compliant matte tin over nickel MSS5131-222ML_ 2.2 0.020 65.0 1.76 2.08 2.30 2.00 3.30 over phos bronze (current production) MSS5131-332ML_ 3.3 0.028 60.0 1.33 1.58 1.73 1.60 2.90 or gold over nickel over phos bronze MSS5131-472ML_ 4.7 0.038 48.0 1.08 1.32 1.42 1.40 2.50 (prior production). MSS5131-562ML_ 5.6 0.042 44.0 1.00 1.20 1.30 1.30 2.30Special order: T MSS5131-682ML_ 6.8 0.050 42.0 0.98 1.14 1.24 1.20 2.16 = RoHS tin-silver-copper (95.5/4/0.5) over gold over nickel over phos bronze MSS5131-822ML_ 8.2 0.058 40.0 0.90 1.04 1.18 1.10 2.00 orS = non-RoHS tin-lead (63/37) over MSS5131-103ML_ 10 0.070 38.0 0.85 0.98 1.13 1.00 1.90 gold over nickel over phos bronze. MSS5131-123ML_ 12 0.080 35.0 0.72 0.85 0.94 0.97 1.60Packaging: C =7 ″machine-ready reel EIA-481 em- bossed plastic tape (600 per full reel). MSS5131-153ML_ 15 0.100 32.0 0.67 0.78 0.86 0.94 1.50 Quantities less than full reel available: MSS5131-183ML_ 18 0.120 26.0 0.61 0.72 0.79 0.89 1.40 in tape (not machine ready) or with MSS5131-223ML_ 22 0.145 22.0 0.54 0.64 0.70 0.87 1.30 leader and trailer ($25 charge). MSS5131-273ML_ 27 0.161 19.0 0.48 0.56 0.62 0.85 1.20D =13 ″machine-ready reel EIA-481 embossed plastic tape. Factory order MSS5131-333ML_ 33 0.200 18.0 0.44 0.52 0.58 0.80 1.10 only, not stocked (2500 per reel per MSS5131-393ML_ 39 0.215 17.0 0.42 0.50 0.55 0.74 1.00 full reel). MSS5131-473ML_ 47 0.270 16.0 0.38 0.46 0.51 0.71 0.95B =Less than full reel Less than full MSS5131-563ML_ 56 0.280 15.0 0.34 0.42 0.47 0.70 0.90 reel. In an effort to simplify our part numbering system, Coilcraft is elimi- MSS5131-683ML_ 68 0.368 12.5 0.31 0.38 0.42 0.66 0.85 nating the need for multiple packaging MSS5131-823ML_ 82 0.420 12.0 0.27 0.32 0.35 0.62 0.80 codes. When ordering, simply change MSS5131-104ML_ 100 0.580 11.5 0.26 0.30 0.33 0.55 0.69 the last letter of your part number MSS5131-124ML_ 120 0.610 11.0 0.23 0.27 0.30 0.51 0.62 from B to D. 2. Inductance tested at 100 kHz, 0.1 Vrms, 0 Adc using an MSS5131-154ML_ 150 0.820 10.0 0.21 0.26 0.28 0.47 0.58 Agilent/HP 4263B LCR meter or equivalent. MSS5131-184ML_ 180 1.00 9.0 0.19 0.23 0.25 0.43 0.54 3. SRF measured using Agilent/HP 4191A or equilvalent. MSS5131-224ML_ 220 1.10 8.0 0.18 0.21 0.23 0.39 0.50 4. DC current at 25°C that causes the specified induc- MSS5131-274ML_ 270 1.43 7.5 0.15 0.18 0.20 0.35 0.45 tance drop from its value without current. Click for temperature derating information. MSS5131-334ML_ 330 1.58 6.8 0.13 0.17 0.19 0.32 0.42 5. Current that causes the specified temperature rise from MSS5131-394ML_ 390 1.80 5.4 0.12 0.15 0.16 0.30 0.38 25°C ambient. This information is for reference only and does not represent absolute maximum ratings. Click for temperature derating information. 6. Electrical specifications at 25°C. Refer to Doc 362 “Soldering Surface Mount Components” before soldering.US +1-847-639-6400 sales@coilcraft.com Document 642-1 Revised 04/26/22UK +44-1236-730595 sales@coilcraft-europe.com © Coilcraft Inc. 2022Taiwan +886-2-2264 3646 sales@coilcraft.com.tw This product may not be used in medical or highChina +86-21-6218 8074 sales@coilcraft.com.cn risk applications without prior Coilcraft approval. Specification subject to change without notice.Singapore + 65-6484 8412 sales@coilcraft.com.sg Please check web site for latest information.
