Datasheet TMP35, TMP36, TMP37 (Analog Devices)
DescriptionLow Voltage Temperature Sensors
Pages / Page19 / 1 — Low Voltage Temperature Sensors. Data Sheet. TMP35/TMP36/TMP37. FEATURES. …
File Format / SizePDF / 456 Kb
Low Voltage Temperature Sensors. Data Sheet. TMP35/TMP36/TMP37. FEATURES. FUNCTIONAL BLOCK DIAGRAM
Datasheet TMP35, TMP36, TMP37 Analog Devices
Low Voltage Temperature Sensors Data Sheet TMP35/TMP36/TMP37 FEATURES FUNCTIONAL BLOCK DIAGRAM Low voltage operation (2.7 V to 5.5 V) +VS (2.7V TO 5.5V) Calibrated directly in °C 10 mV/°C scale factor (20 mV/°C on TMP37) ±2°C accuracy over temperature (typ) TMP35/ SHUTDOWN TMP36/ VOUT ±0.5°C linearity (typ) TMP37 Stable with large capacitive loads
001
Specified −40°C to +125°C, operation to +150°C
00337-
Less than 50 µA quiescent current
Figure 1.
Shutdown current 0.5 µA max Low self-heating PIN CONFIGURATIONS Qualified for automotive applications V 1 5 GND APPLICATIONS OUT +V TOP VIEW Environmental control systems S 2 (Not to Scale) Thermal protection NC 3 4 SHUTDOWN Industrial process control NC = NO CONNECT
00337-002
Fire alarms Power system monitors
Figure 2. RJ-5 (SOT-23)
CPU thermal management GENERAL DESCRIPTION V 1 8 OUT +VS NC 2 7 NC
The TMP35/TMP36/TMP37 are low voltage, precision centi-
TOP VIEW NC 3 (Not to Scale) 6 NC
grade temperature sensors. They provide a voltage output that
GND 4 5 SHUTDOWN
is linearly proportional to the Celsius (centigrade) temperature. The TMP35/TMP36/TMP37 do not require any external
NC = NO CONNECT
00337-003 calibration to provide typical accuracies of ±1°C at +25°C Figure 3. R-8 (SOIC_N) and ±2°C over the −40°C to +125°C temperature range. The low output impedance of the TMP35/TMP36/TMP37 and
1 2 3
its linear output and precise calibration simplify interfacing to
BOTTOM VIEW (Not to Scale)
temperature control circuitry and ADCs. All three devices are intended for single-supply operation from 2.7 V to 5.5 V maxi-
PIN 1, +VS; PIN 2, VOUT; PIN 3, GND
00337-004 mum. The supply current runs well below 50 µA, providing very low self-heating—less than 0.1°C in still air. In addition, a Figure 4. T-3 (TO-92) shutdown function is provided to cut the supply current to less than 0.5 µA. The TMP35 is functionally compatible with the LM35/LM45 The TMP37 is intended for applications over the range of 5°C and provides a 250 mV output at 25°C. The TMP35 reads to 100°C and provides an output scale factor of 20 mV/°C. The temperatures from 10°C to 125°C. The TMP36 is specified from TMP37 provides a 500 mV output at 25°C. Operation extends −40°C to +125°C, provides a 750 mV output at 25°C, and to 150°C with reduced accuracy for al devices when operating operates to 125°C from a single 2.7 V supply. The TMP36 is from a 5 V supply. functional y compatible with the LM50. Both the TMP35 and The TMP35/TMP36/TMP37 are available in low cost 3-lead TMP36 have an output scale factor of 10 mV/°C. TO-92, 8-lead SOIC_N, and 5-lead SOT-23 surface-mount packages.
Rev. H Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©1996–2015 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
