Datasheet 16C18 (Portescap)
ManufacturerPortescap
DescriptionBrush DC Motors
Pages / Page1 / 1 — Brush DC Motors 16C18. Electrical Data. Symbol. 16C18 •••• .67. Unit. …
File Format / SizePDF / 345 Kb
Brush DC Motors 16C18. Electrical Data. Symbol. 16C18 •••• .67. Unit. 115. 210. 207. 205. 204. General Data. Execution Table
Datasheet 16C18 Portescap
Ø 16 mm • Precious metal commutation • 1.12 mNm Ø10 Ø10 Ø10 2xM1.6x1.4 Max. 2xM1.6x1.4 Max. 0 -0.1 0 -0.1 0 -0.1 0 -0.1 0 -0.1 0 -0.1 2xM1.6x1.4 Max. 15 16 15 16 0 -0.018 15 16 0 15 16 -0.018 15 16 0 -0.018 0 -0.018 0 15 16 -0.018 0 -0.018 Ø Ø Ø -0.006 Ø -0.009 Ø -0.006 Ø-0.009 Ø Ø -0.006 -0.009 Ø Ø Ø Ø 6.8 6.8 6.8 6.8 0 -0.006 6.8 0 -0.006 6.8 -0.006 Ø 1.5 Ø 1.5 Ø 1.5 Ø 1 Ø 1 Ø 0 1 Ø Ø Ø Ø Ø - + Ø - + - + 5.9 5.9 5.9 4 4 4 3.7 1 3.7 (6.5) 1 3.7 (6.5) 13.7 (6.5) 1 3(.7 5.7) 1 3(.7 5. ) 150±3 1 (5.7) 150±3 150±3 2 15.7 2 15.7 7.5 2 15.7 7.5 2 7.5 15.7 2 15.7 6.7 26.7 15.7 6.7 Dimensions in mm.
Electrical Data Symbol 16C18 •••• .67 Unit 115 210 207 205 204
1 Nominal Voltage V 1.5 4 6 12 15 Volt 2 No-Load Speed n0 15,300 14,700 15,700 16,200 16,000 rpm 3 No-Load Current I0 74.8 23.0 18.4 10.4 6.9 mA 4 Terminal Resistance R 1.2 7.5 18.0 65.0 162.0 Ω 5 Output Power P2max. 0.7 0.8 0.7 0.8 0.7 W 6 Stall Torque mNm 1.1 1.3 1.1 1.2 0.8 mNm (oz-in) 7 Efficiency hmax. 57 63 59 58 53 % 8 Max Continuous Speed ne max. 10,000 10,000 10,000 10,000 10,000 rpm 9 Max Continuous Torque Me max. 0.98 (0.15) 1.12 (0.15) 1 (0.15) 1 (0.14) 0.79 (0.11) mNm (oz-in) 10 Max Continuous Current Ie max. 1.19 0.48 0.31 0.16 0.10 A 11 Back-EMF Constant kE 0.09 0.26 0.36 0.70 0.87 mV/rpm 12 Torque Constant kM 0.88 2.48 3.44 6.68 8.30 mNm/A 13 Motor Regulation R/k2 1555.0 1220.0 1520.0 1460.00 2350.00 103/Nms 14 Friction Torque TF 0.07 (0.02) 0.06 (0.01) 0.06 (0.01) 0.07 (0.02) 0.06 (0.01) mNm (oz-in) 15 Rotor Inductance L 20.00 150.00 250.00 1000.00 1000.00 mH 16 Mechanical Time Constant τm 48.0 50.0 41.0 60.0 63.0 ms 17 Rotor Inertia J 0.31 0.41 0.27 0.41 0.27 g-cm2
General Data
18 Thermal Resistance (rotor/body) R / th1 Rth2 15/40 °C/W 19 Thermal Time Constant (rotor/stator) tW1/tW2 4/230 S 20 Operating Temperature Range: motor -30°C to 85°C (-22°F to 185°F) °C (°F) rotor 100°C (212°F) °C (°F) 21 Shaft Load Max.: With sleeve bearings (5 mm. from bearing) -radial 1.5 (5.4) N (oz) -axial 100 (359.6) N (oz) 22 Shaft Play: -radial <0.03 (0.0012) mm (inch) -axial 0.15 (0.0059) mm (inch) 23 Weight g 14 (0.49) g (oz) 24 Commutation Segment - 5 segment
Execution Table No Load Speed vs. Torque
10000
Gearbox Single Shaft F16
Max. Recommended Speed B16 67 76 8000 Max. Continuous Output BA16 67 76
Power 0.85W 6000 R16 30 76
n (rpm
4000 2000 0 0 1 2 3 5 Motor shaft rotates CW when seen from motor front face
M (mNm)
when +ve and -ve supply is given to respective terminals. Continuous working range Temporary working range V012021
© 2021 Portescap. Specifications subject to change without notice.
73
