Datasheet ZUW10 (Cosel)
ManufacturerCosel
DescriptionDC-DC Converters PCB Mount Type
Pages / Page2 / 1 — DC-DC Converters PCB Mount type. Ordering information. ZUW10. MODEL
File Format / SizePDF / 108 Kb
Datasheet ZUW10 Cosel
DC-DC Converters PCB Mount type Ordering information ZUW10 ZU W 10 12 12
1 2 3 4 5 1Series name R 2Dual output 3Output wattage 4Input voltage 5Output voltage
MODEL ZUW100512 ZUW100515 ZUW101212 ZUW101215 ZUW102412 ZUW102415 ZUW104812 ZUW104815 MAX OUTPUT WATTAGE[W] 8.4 9.0 10.8 10.5 10.8 10.5 10.8 10.5 VOLTAGE[V]
t
12 or +24
t
15 or +30
t
12 or +24
t
15 or +30
t
12 or +24
t
15 or +30
t
12 or +24
t
15 or +30 DC OUTPUT CURRENT[A] 0.35 0.30 0.45 0.35 0.45 0.35 0.45 0.35 SPECIFICATIONS
Output pins can be connected in series to make a 24V/30V output.
MODEL ZUW100512 ZUW100515 ZUW101212 ZUW101215 ZUW102412 ZUW102415 ZUW104812 ZUW104815 VOLTAGE[V]
DC4.5 - 9 DC9 - 18 DC18 - 36 DC36 - 72
INPUT CURRENT[A]
*1 2.24typ 2.40typ 1.12typ 1.09typ 0.56typ 0.55typ 0.28typ 0.28typ
EFFICIENCY[%]
*1 75typ 75typ 81typ 81typ 81typ 81typ 81typ 81typ
VOLTAGE[V]
t12 (+24) t15 (+30) t12 (+24) t15 (+30) t12 (+24) t15 (+30) t12 (+24) t15 (+30)
CURRENT[A]
LINE REGULATION[mV]
60max 75max 60max 75max 60max 75max 60max 75max
LOAD REGULATION[mV]
600max 750max 600max 750max 600max 750max 600max 750max
ZU/ZT RIPPLE[mVp-p]
*2 120max 120max 120max 120max 120max 120max 120max 120max
OUTPUT RIPPLE NOISE[mVp-p]
*2 150max 150max 150max 150max 150max 150max 150max 150max
TEMPERATURE REGULATION[mV] -20 to +55
C 150max 180max 150max 180max 150max 180max 150max 180max
DRIFT[mV]
*3 50max 60max 50max 60max 50max 60max 50max 60max
START-UP TIME[ms]
20max (Minimum input, Io=100%)
OUTPUT VOLTAGE ADJUSTMENT RANGE[V]
Fixed
OUTPUT VOLTAGE SETTING[V]
11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75
PROTECTION CIRCUIT OVERCURRENT PROTECTION
Works over 105% of rating and recovers automatically
INPUT-OUTPUT
AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C)
ISOLATION INPUT-CASE
OUTPUT-CASE
OPERATING TEMP.,HUMID.AND ALTITUDE
-20 to +71C, 20 - 95%RH (Non condensing) (Refer to DERATING CURVE), 3,000m (10,000feet) max
STORAGE TEMP.,HUMID.AND ALTITUDE
-40 to +85C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max
ENVIRONMENT VIBRATION
10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis
IMPACT
490.3m/s2 (50G), 11ms, once each X, Y and Z axis
SAFETY AGENCY APPROVALS
UL60950-1, EN60950-1, CSA C22.2 No.60950-1 Complies with IEC60950-1
CASE SIZE/WEIGHT
45X7X35mm (WXHXD) / 40g max
OTHERS COOLING METHOD
Convection *1 Rated input 5V, 12V, 24V or 48V DC, Io=100%. *2 Measured by 20MHz oscilloscope. *3 The drift is a change at 25C of ambient temperature and 30 minutes - 8 hours after the input voltage applied at rated input/output. * The output specification is at t12V and t15V. * Series/Parallel operation with other model is not possible.
ZU/ZT-24
June 29, 2011
