Datasheet MBR350, MBR360 (ON Semiconductor) - 2
ManufacturerON Semiconductor
DescriptionAxial Lead Rectifiers
Pages / Page6 / 2 — MBR350, MBR360. ELECTRICAL CHARACTERISTICS. Characteristic. Symbol. Max. …
File Format / SizePDF / 167 Kb
MBR350, MBR360. ELECTRICAL CHARACTERISTICS. Characteristic. Symbol. Max. Unit. Figure 2. Typical Reverse Current*
MBR350, MBR360 ELECTRICAL CHARACTERISTICS Characteristic Symbol Max Unit Figure 2 Typical Reverse Current*
link to page 2 link to page 2 link to page 2 link to page 3
(TL = 25C unless otherwise noted) (Note 2)
Maximum Instantaneous Forward Voltage (Note 3) vF V (iF = 1.0 A) 0.600 (iF = 3.0 A) 0.740 (iF = 9.4 A) 1.080 Maximum Instantaneous Reverse Current @ Rated DC Voltage (Note 3) iR mA TL = 25C 0.60 TL = 100C 20 Product parametric performance is indicated in the Electrical Characteristics for the listed test conditions, unless otherwise noted. Product performance may not be indicated by the Electrical Characteristics if operated under different conditions. 2. Lead Temperature reference is cathode lead 1/32 in from case. 3. Pulse Test: Pulse Width = 300 ms, Duty Cycle = 2.0%. 20 20 10 TJ = 150C TJ = 100C 75C 25C 5.0 10 (mA) 2.0 100C 1.0 7.0 0.50 75C 5.0 0.20 *The curves shown are typical for the highest 0.10 voltage device in the voltage grouping. Typical 0.05 reverse current for lower voltage selections can 3.0 R 0.02 be estimated from these same curves if V I , REVERSE CURRENT R is sufficiently below rated V (AMPS) 0.01 R. 2.0 25C 0.005 0.002 1.0 0 10 20 30 40 50 60 80 ARD CURRENT VR REVERSE VOLTAGE (VOLTS) W 0.7
0.5 5.0 ANEOUS FOR 0.3 (AMPS) RATED VR ANT 0.2 R 4.0 qJA = 28C/W i , INST F DC 0.1 3.0 ARD CURRENT SQUARE W WAVE 0.07 2.0 0.05 VERAGE FOR A 1.0 0.03 T V) J = 150C I , F (A 0.02 0 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 0 20 40 60 80 100 120 140 160 vF, INSTANTANEOUS VOLTAGE (VOLTS) TA, AMBIENT TEMPERATURE (C)
Figure 1. Typical Forward Voltage Figure 3. Current Derating Ambient
(Mounting Method 3 per Note 4)
www.onsemi.com 2
