Datasheet BL8506 (Belling)
ManufacturerBelling
DescriptionHigh-Precision Low Voltage Detector
Pages / Page19 / 1 — BL8506. High-Precision Low Voltage Detector. DESCRIPTION. FEATURES. …
File Format / SizePDF / 876 Kb
BL8506. High-Precision Low Voltage Detector. DESCRIPTION. FEATURES. APPLICATIONS. TYPICAL APPLICATION. ELECTRICAL CHARACTERISTICS
Datasheet BL8506 Belling
BL8506
BL8506 High-Precision Low Voltage Detector DESCRIPTION FEATURES
BL8506 is a series of high precision voltage • High-precision detection voltage: ±2% detector with ultra-low current consumption • Detection voltage: 0.9V~6.0V (in 0.1V step) (500nA typ. at VDD=3.0V). It can work at very low • Precise hysteresis: 4% (Typ.) voltage, which makes it perfect for system reset. • Operating voltage range: 0.7V~10V BL8506 is composed of high precision voltage • Ultra-low current consumption: reference, comparator, output driver and resistor 500nA typ. (at VDD=3.0V) array. Internally preset detect voltage has a low • Two output forms: temperature drift and requires no external CMOS (active low) or trimming. N-channel open-drain (active low)
Two forms of output, CMOS and N-channel open-
drain, are available. • Power monitor for portable equipment such BL8506 is available in SOT23, SOT23-3, SOT23-5, as PDA, DSC, mobile phone, notebook, MP3 SC-82, SOT89-3, TO-92 packages which are Pb-free. • CPU and logic circuit reset • Battery checker • Battery back-up circuit • Power failure detector
TYPICAL APPLICATION ELECTRICAL CHARACTERISTICS Detector Threshold=0.9V
VDD R0 1.E-05 VIN BL8506 VOUT (A) 1.E-06 V SS t n rre u c yl 1.E-07 p p
Note:
-40ºC Su 25ºC R0 is unnecessary for CMOS output products. 70ºC 1.E-08 The value of R0 need to be selected in different 0 1 2 3 4 5 6 applications and the typical value is 470KΩ. Input voltage (V)
www.belling.com.cn 1
