Datasheet VCNL36828P (Vishay) - 2
ManufacturerVishay
DescriptionA Small Package Proximity Sensor With a VCSEL, Low Idle Current, I 2C Interface, and Smart Dual Slave Address
Pages / Page20 / 2 — VCNL36828P. PIN DEFINITION. PIN DESCRIPTION. PIN NUMBER. PIN NAME. TYPE. …
File Format / SizePDF / 287 Kb
VCNL36828P. PIN DEFINITION. PIN DESCRIPTION. PIN NUMBER. PIN NAME. TYPE. DESCRIPTION. Note. ABSOLUTE MAXIMUM RATINGS. PARAMETER
VCNL36828P PIN DEFINITION PIN DESCRIPTION PIN NUMBER PIN NAME TYPE DESCRIPTION Note ABSOLUTE MAXIMUM RATINGS PARAMETER
VCNL36828P
PIN DEFINITION
INT 1 6 SDA ASIC PD V 2 5 SCL DD VCSEL GND 3 4 VCSELA
1 INT O (open drain) Interrupt 2 VDD I Supply voltage 3 GND I Ground 4 VCSELA I VCSEL anode 5 SCL (1) I / O (open drain) I2C serial clock 6 SDA (1) I / O (open drain) I2C serial data
Note
(1) Pin 5 (SCL) and pin 6 (SDA) can be swapped to change the slave address from 0x60 to 0x51; please refer to Table 1
(Tamb = 25 °C, unless otherwise specified)
PARAMETER TEST CONDITION SYMBOL MIN. MAX. UNIT
Supply voltage VDD 0 2 V Ambient temperature range Tamb -40 +85 °C Storage temperature range Tstg -40 +100 °C Rev. 1.2, 16-Nov-2023
2
Document Number: 80306 For technical questions, contact: sensorstechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
