Datasheet LTC2270 (Analog Devices) - 4
Description16-Bit, 20Msps Low Noise Dual ADC
Pages / Page36 / 4 — CONVERTER CHARACTERISTICS. The. denotes the specifications which apply …
File Format / SizePDF / 593 Kb
CONVERTER CHARACTERISTICS. The. denotes the specifications which apply over the full operating
CONVERTER CHARACTERISTICS The denotes the specifications which apply over the full operating
LTC2270
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 5) PARAMETER CONDITIONS MIN TYP MAX UNITS
Resolution (No Missing Codes) l 16 Bits Integral Linearity Error Differential Analog Input (Note 6) l –2.3 ±1 2.3 LSB Differential Linearity Error Differential Analog Input l –0.8 ±0.2 0.8 LSB Offset Error (Note 7) l –7 ±1.3 7 mV Gain Error Internal Reference ±1.2 %FS External Reference l –1.6 –0.3 1 %FS Offset Drift ±10 μV/°C Full-Scale Drift Internal Reference ±30 ppm/°C External Reference ±10 ppm/°C Gain Matching l –0.2 ±0.06 0.2 %FS Offset Matching l –10 ±1.5 10 mV Transition Noise 1.44 LSBRMS
ANALOG INPUT The
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 5) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
V + – IN Analog Input Range (AIN – AIN ) 1.7V < VDD < 1.9V l 1 to 2.1 VP-P V + – IN(CM) Analog Input Common Mode (AIN + AIN )/2 Differential Analog Input (Note 8) l 0.65 VCM VCM + 200mV V VSENSE External Voltage Reference Applied to SENSE External Reference Mode l 0.625 1.250 1.300 V IINCM Analog Input Common Mode Current Per Pin, 20Msps 32 μA I + – IN1 Analog Input Leakage Current (No Encode) 0 < AIN , AIN < VDD l –1 1 μA IIN2 PAR/SER Input Leakage Current 0 < PAR/SER < VDD l –1 1 μA IIN3 SENSE Input Leakage Current 0.625 < SENSE < 1.3V l –2 2 μA tAP Sample-and-Hold Acquisition Delay Time 0 ns tJITTER Sample-and-Hold Acquisition Delay Jitter Single-Ended Encode 85 fsRMS Differential Encode 100 fsRMS CMRR Analog Input Common Mode Rejection Ratio 80 dB BW-3B Full-Power Bandwidth Figure 5 Test Circuit 200 MHz 2270f 4
