Datasheet AD8476 (Analog Devices) - 4
DescriptionLow Power, Unity Gain Fully Differential Amplifier & ADC Driver
Pages / Page24 / 4 — AD8476. Data Sheet. B Grade. A Grade. Parameter. Test …
File Format / SizePDF / 516 Kb
AD8476. Data Sheet. B Grade. A Grade. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
AD8476 Data Sheet B Grade A Grade Parameter Test Conditions/Comments Min Typ Max Unit
AD8476 Data Sheet B Grade A Grade Parameter Test Conditions/Comments Min Typ Max Min Typ Max Unit
POWER SUPPLY Specified Supply Voltage ±5 ±5 V Operating Supply Voltage 3 18 3 18 V Range Supply Current VS = +5 V, TA = 25°C 300 330 300 330 μA VS = ±5 V, TA = 25°C 330 380 330 380 μA Over Temperature −40°C ≤ TA ≤ +125°C 400 500 400 500 μA TEMPERATURE RANGE Specified Performance Range −40 +125 −40 +125 °C 1 Includes amplifier voltage and current noise, as well as noise of internal resistors. 2 Includes input bias and offset current errors. 3 The input voltage range is a function of the voltage supplies and ESD diodes. 4 Internal resistors are trimmed to be ratio matched but have ±20% absolute accuracy. Rev. B | Page 4 of 24 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Absolute Maximum Ratings Thermal Resistance Maximum Power Dissipation ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Terminology Theory of Operation Overview Circuit Information Output Common-Mode Voltage (VOCM) DC Precision Input Voltage Range Driving the AD8476 Power Supplies Applications Information Typical Configuration Single-Ended-to-Differential Conversion Setting the Output Common-Mode Voltage Low Power ADC Driving Outline Dimensions Ordering Guide
