Datasheet AD842 (Analog Devices) - 5
DescriptionWideband, High Output Current, Fast Settling Op Amp
Pages / Page16 / 5 — Data Sheet. AD842. TYPICAL PERFORMANCE CHARACTERISTICS. E (V) 15. G N. …
RevisionF
File Format / SizePDF / 362 Kb
Data Sheet. AD842. TYPICAL PERFORMANCE CHARACTERISTICS. E (V) 15. G N. mA). ( NT. E R D. -MO 10. CURRE NT. MMO. VIN. UI 12. PU IN
Data Sheet AD842 TYPICAL PERFORMANCE CHARACTERISTICS E (V) 15 G N mA) ( NT E R D -MO 10 CURRE NT MMO VIN UI 12 PU IN
TA = 25°C and VS = ±15 V, unless otherwise noted.
20 18 E (V) 15 16 G N mA) A ( NT E R D -MO 10 14 N CURRE NT MMO VIN CE O S C E T 5 UI 12 Q PU IN 0 10 0 5 10 15 20
004
0 5 10 15 20
007
SUPPLY VOLTAGE (±V)
09477-
SUPPLY VOLTAGE (±V)
09477- Figure 4. Input Common-Mode Range vs. Supply Voltage Figure 7. Quiescent Current vs. Supply Voltage
20 –5 ) V 15 A) G ( µ ( –4 WIN NT S GE 10 CURRE OLTA ±VOUT AS T V BI U –3 UT TP 5 INP OU 0 –2
008
0 5 10 15 20
005
–60 –40 –20 0 20 40 60 80 100 120 140 SUPPLY VOLTAGE (±V)
09477-
TEMPERATURE (°C)
09477- Figure 5. Output Voltage Swing vs. Supply Voltage Figure 8. Input Bias Current vs. Temperature
30 100 25 p) ) 10 p- ±15V SUPPLIES V (Ω 20 G ( WIN S 15 PEDANCE 1 GE IM OLTA 10 PUT T V UT U O 0.1 TP 5 OU 0 0.01
006
10 100 1k 10k 10k 100k 1M 10M 100M
009
LOAD RESISTANCE (Ω)
09477-
FREQUENCY (Hz)
09477- Figure 6. Output Voltage Swing vs. Load Resistance Figure 9. Output Impedance vs. Frequency Rev. F | Page 5 of 16 Document Outline Features Applications Connection Diagrams General Description Product Highlights Table of Contents Revision History Specifications Electrical Characteristics—±15 V Operation Absolute Maximum Ratings Thermal Characteristics ESD Caution Metalization Photograph Typical Performance Characteristics Theory of Operation Offset Nulling Settling Time Grounding and Bypassing Capacitive Load Driving Ability Using a Heat Sink Terminated Line Driver Overdrive Recovery Outline Dimensions Ordering Guide
