Datasheet AD8065, AD8066 (Analog Devices) - 3
DescriptionHigh Performance, 145 MHzFastFETTM Op Amp
Pages / Page28 / 3 — Data Sheet. AD8065/AD8066. REVISION HISTORY. 8/2016—Rev. K to Rev. J. …
RevisionL
File Format / SizePDF / 494 Kb
Data Sheet. AD8065/AD8066. REVISION HISTORY. 8/2016—Rev. K to Rev. J. 8/2010—Rev. I to Rev. J. 2/2004—Rev. D to Rev. E
Data Sheet AD8065/AD8066 REVISION HISTORY 8/2016—Rev K to Rev J 8/2010—Rev I to Rev J 2/2004—Rev D to Rev E
AD8065
AD8066
Data Sheet AD8065/AD8066 REVISION HISTORY 8/2016—Rev. K to Rev. J
Changes to Figure 22 through Figure 27.. 11 Updated Outline Dimensions .. 27 Updated Outline Dimensions.. 25 Changes to Ordering Guide ... 28
Changes to Ordering Guide ... 26
8/2010—Rev. I to Rev. J 2/2004—Rev. D to Rev. E.
Changes to Features Section, Applications Section, and General Updated Format .. Universal Description Section ... 1 Updated Figure 56 ... 21 Change to Table 1 .. 4 Updated Outline Dimensions.. 25 Change to Table 3 .. 7 Updated Ordering Guide ... 26
Changes to Table 4 .. 9
11/2003—Rev. C to Rev. D.
Changes to Figure 9... 10 Changes to Features ... 1 Changes to Inverting Closed-Loop Frequency Response Changes to Connection Diagrams ... 1 Section .. 20 Updated Ordering Guide .. 5 Moved Leakage Currents Section, Input Capacitance Section, Updated Outline Dimensions.. 22
and Output Capacitance Section ... 23
4/2003—Rev. B to Rev. C.
Moved Input-to-Input Coupling Section, Wideband Added SOIC-8 (R) for the AD8065 ... 4 Photodiode Preamp Section, and Figure 59 .. 24 Changes to Table 5 .. 25
2/2003—Rev. A to Rev. B.
Moved Figure 60 and High Speed JFET Input Instrumentation Changes to Absolute Maximum Ratings... 4 Amplifier Section .. 25 Changes to Test Circuit 10 ... 14 Updated Outline Dimensions .. 27 Changes to Test Circuit 11 ... 15 Changes to Ordering Guide ... 28 Changes to Noninverting Closed-Loop Frequency Response 16 Added Automotive Products Section ... 28 Changes to Inverting Closed-Loop Frequency Response ... 16 Updated Figure 6 .. 18
3/2009—Rev. H to Rev. I
Changes to Figure 7 .. 19 Changes to High Speed JFET Input Instrumentation Amplifier Changes to Figure 10 .. 21 Section .. 23 Changes to Figure 11 .. 22 Updated Outline Dimensions .. 24 Changes to High Speed JFET Instrumentation Amplifier .. 22
9/2008—Rev. G to Rev. H
Changes to Video Buffer .. 22 Deleted Usable Range Parameter, Table 1 .. 3
8/2002—Rev. 0 to Rev. A.
Deleted Usable Range Parameter, Table 2 .. 4 Added AD8066 .. Universal Deleted Usable Range Parameter, Table 3 .. 5 Added SOIC-8 (R) and MSOP-8 (RM) ... 1 Changes to Layout ... 6 Edits to General Description .. 1 Changes to Input and Output Overload Behavior Section .. 19 Edits to Specifications .. 2 Changes to Table 5 Expressions Column ... 22 New Figure 2 ... 5
1/2006—Rev. F to Rev. G
Changes to Ordering Guide .. 5 Changes to Ordering Guide ... 26 Edits to TPCs 18, 25, and 28 ... 8
12/2005—Rev. E to Rev. F
New TPC 36 ... 11 Updated Format.. Universal Added Test Circuits 10 and 11 .. 14 Changes to Features .. 1 MSOP (RM-8) Added .. 23 Changes to General Description ... 1 Rev. K | Page 3 of 28 Document Outline FEATURES APPLICATIONS CONNECTION DIAGRAMS GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ±5 V SPECIFICATIONS ±12 V SPECIFICATIONS +5 V ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION OUTPUT SHORT CIRCUIT ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS SOIC-8 Pinout THEORY OF OPERATION CLOSED-LOOP FREQUENCY RESPONSE NONINVERTING CLOSED-LOOP FREQUENCY RESPONSE INVERTING CLOSED-LOOP FREQUENCY RESPONSE WIDEBAND OPERATION INPUT PROTECTION THERMAL CONSIDERATIONS INPUT AND OUTPUT OVERLOAD BEHAVIOR LAYOUT, GROUNDING, AND BYPASSING CONSIDERATIONS POWER SUPPLY BYPASSING GROUNDING LEAKAGE CURRENTS INPUT CAPACITANCE OUTPUT CAPACITANCE INPUT-TO-OUTPUT COUPLING WIDEBAND PHOTODIODE PREAMP HIGH SPEED JFET INPUT INSTRUMENTATION AMPLIFIER VIDEO BUFFER OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
