Datasheet MAX4238, MAX4239 (Maxim) - 2
ManufacturerMaxim
Pages / Page9 / 2 — Absolute Maximum Ratings. Electrical Characteristics. PARAMETER. SYMBOL. …
Absolute Maximum Ratings. Electrical Characteristics. PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. UNITS
Absolute Maximum Ratings Electrical Characteristics PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
MAX4238/MAX4239 Ultra-Low Offset/Drift, Low-Noise, Precision SOT23 Amplifiers
Power-Supply Voltage (VCC to GND) ...6V Operating Temperature Range ... -40°C to +125°C All Other Pins ..(VGND - 0.3V) to (VCC + 0.3V) Junction Temperature ..+150°C Output Short-Circuit Duration Storage Temperature Range .. -65°C to +150°C (OUT shorted to VCC or GND) ...Continuous Lead Temperature (soldering, 10s) ...+300°C Continuous Power Dissipation (TA = +70°C) Soldering Temperature (reflow) 6-Pin Plastic SOT23 Lead(Pb)-Free Packages ..+260°C (derate 9.1mW/°C above +70°C) ..727mW Packages Containing Lead..+240°C 8-Pin Plastic SO (derate 5.88mW/°C above +70°C) ...471mW 6-Pin TDFN-EP (derate 18.2mW above +70°C) ...1454mW Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability.
(2.7V ≤ VCC ≤ 5.5V, VCM = VGND = 0V, VOUT = VCC/2, RL = 10kΩ connected to VCC/2, SHDN = VCC, TA = +25°C, unless otherwise noted.)
Input Offset Voltage VOS (Note 1) 0.1 2 µV Long-Term Offset Drift 50 nV/1000hr Input Bias Current IB (Note 2) 1 pA Input Offset Current IOS (Note 2) 2 pA Peak-to-Peak Input Noise Voltage enP-P RS = 100Ω, 0.01Hz to 10Hz 1.5 µVP-P Input Voltage-Noise Density en f = 1kHz 30 NV/√Hz Common-Mode Input VCC Voltage Range VCM Inferred from CMRR test VGND - 0.1 - 1.3 V Common-Mode Rejection Ratio CMRR -0.1V ≤ VCM ≤ VCC - 1.3V (Note 1) 120 140 dB Power-Supply Rejection Ratio PSRR 2.7V ≤ VCC ≤ 5.5V (Note 1) 120 140 dB 0.05V ≤ VOUT ≤ VCC - 0.05V (Note 1) RL = 10kΩ 125 150 Large-Signal Voltage Gain AVOL dB 0.1V ≤ VOUT ≤ VCC - 0.1V (Note 1) RL = 1kΩ 125 145 V R CC - VOH 4 10 L = 10kΩ V Output Voltage Swing V OL 4 10 OH/VOL mV V R CC - VOH 35 50 L = 1kΩ VOL 35 50 Output Short-Circuit Current To either supply 40 mA Output Leakage Current 0 ≤ VOUT ≤ VCC, SHDN = GND (Note 2) 0.01 1 µA MAX4238 0.35 Slew Rate VCC = 5V, CL = 100pF, V V/µs OUT = 2V step MAX4239 1.6 MAX4238 1 Gain-Bandwidth Product GBWP RL = 10kΩ, CL = 100pF, measured at f = 100kHz MHz MAX4239 6.5 Minimum Stable Closed-Loop R MAX4238 1 L = 10kΩ, CL = 100pF, Gain phase margin = 60° V/V MAX4239 10 www.maximintegrated.com Maxim Integrated │
2
