Datasheet AD8601, AD8602, AD8604 (Analog Devices) - 10
DescriptionPrecision CMOS, Single-Supply, Rail-to-Rail, Input/Output Wideband Operational Amplifiers
Pages / Page24 / 10 — AD8601/AD8602/AD8604. 200. 160. VS = 5V. 180. TA = 25°C. 140. B) 120. (d …
RevisionG
File Format / SizePDF / 352 Kb
AD8601/AD8602/AD8604. 200. 160. VS = 5V. 180. TA = 25°C. 140. B) 120. (d N. (Ω 140. 100. IO CT. 120. DANCE. AV = 100. E P 100. V = 10. AV = 1. R S. E W. –20. –40
AD8601/AD8602/AD8604 200 160 VS = 5V 180 TA = 25°C 140 B) 120 (d N (Ω 140 100 IO CT 120 DANCE AV = 100 E P 100 V = 10 AV = 1 R S E W –20 –40
AD8601/AD8602/AD8604 200 160 VS = 5V VS = 5V 180 TA = 25°C 140 TA = 25°C 160 B) 120 ) (d N (Ω 140 100 IO CT 120 80 JE DANCE AV = 100 E P 100 RE 60 Y M A L I V = 10 P 80 P 40 UT U P AV = 1 UT 60 R S 20 O E W 40 O 0 P 20 –20 0 –40
29 32
100 1k 10k 100k 1M 10M
0
0 5- 5-
FREQUENCY (Hz)
52
FREQUENCY (Hz)
52 01 01 Figure 29. Output Impedance vs. Frequency Figure 32. Power Supply Rejection Ratio vs. Frequency
160 70 V V S = 3V S = 2.7V 140 T R A = 25°C L = ∞ 60 T ) A = 25°C B) 120 AV = 1 d % ( T N ( 100 O 50 IO O T H C S –OS 80 JE 40 ER V RE 60 E O L +OS D A O 30 40 N -M G N O SI 20 L 20 M L M A 0 CO SM 10 –20 –40 0
30 33
1k 10k 100k 1M 10M 20M
0
10 100 1k
0 5- 5-
FREQUENCY (Hz)
52
CAPACITANCE (pF)
52 01 01 Figure 30. Common-Mode Rejection Ratio vs. Frequency Figure 33. Small Signal Overshoot vs. Load Capacitance
160 70 V V S = 5V S = 5V 140 T R A = 25°C L = ∞ 60 T ) ) A = 25°C B 120 AV = 1 d % ( ( T 100 O 50 ION O T H C S E 80 J 40 ER E V R 60 –OS E O L A OD 30 40 N +OS -M G ON SI 20 L 20 M L A OM 0 C SM 10 –20 –40 0
31 34
0
10 100 1k
0 5- 5-
FREQUENCY (Hz)
52
CAPACITANCE (pF)
52 01 01 Figure 31. Common-Mode Rejection Ratio vs. Frequency Figure 34. Small Signal Overshoot vs. Load Capacitance Rev. G | Page 10 of 24 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION RAIL-TO-RAIL INPUT STAGE INPUT OVERVOLTAGE PROTECTION OVERDRIVE RECOVERY POWER-ON TIME USING THE AD8602 IN HIGH SOURCE IMPEDANCE APPLICATIONS HIGH SIDE AND LOW SIDE, PRECISION CURRENT MONITORING USING THE AD8601 IN SINGLE-SUPPLY, MIXED SIGNAL APPLICATIONS PC100 COMPLIANCE FOR COMPUTER AUDIO APPLICATIONS SPICE MODEL OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
