Datasheet TL601, TL604, TL607, TL610 (Texas Instruments) - 3
ManufacturerTexas Instruments
DescriptionP-MOS ANALOG SWITCHES
Pages / Page9 / 3 — TL601, TL604, TL607, TL610. P-MOS ANALOG SWITCHES
File Format / SizePDF / 103 Kb
TL601, TL604, TL607, TL610 P-MOS ANALOG SWITCHES
TL601
TL604
TL607
TL610
D2161, JUNE 1976 — REVISED OCTOBER 1986
absolute maximum ratings over operating free-air temperature range (unless otherwise noted)
Supply voltage, VCC+ (see Note 1) . 30 V Supply voltage, VCC– . –30 V VCC+ to VCC– supply voltage differential . 35 V Control input voltage . VCC+ Switch off-state voltage . 30 V Switch on-state current . 10 mA Operating free-air temperature range: TL601C, TL604C, TL607C, TL610C . 0°C to 70°C TL601I, TL604I, TL607I, TL610I . – 25°C to 85°C TL601M, TL604M, TL607M, TL610M . – 55°C to 125°C Storage temperature range . – 65°C to 150°C Lead temperature (1,6 mm) 1/16 inch from case for 60 seconds: JG package . 300°C Lead temperature (1,6 mm) 1/16 inch from case for 10 seconds: P package . 260°C NOTE 1: All voltage values are with respect to network ground terminal.
recommended operating conditions TL601C, TL604C TL601I, TL604I TL601M, TL604M TL607C, TL610C TL607I, TL610I TL607M, TL610M UNIT MIN TYP MAX MIN TYP MAX MIN TYP MAX
Supply voltage, VCC+ (see Figure 1) 5 10 25 5 10 25 5 10 25 V Supply voltage, VCC– (see Figure 1) – 5 – 20 – 25 – 5 – 20 – 25 – 5 – 20 – 25 V VCC+ to VCC– supply voltage differential 15 30 15 30 15 30 V (see Figure 1) High-level control input voltage, VIH 2 5.5 2 5.5 2 5.5 V Low-level control input voltage, VIL All inputs 0.8 0.8 0.8 Voltage at any analog switch (S) terminal VCC– + 8 VCC+ VCC– + 8 VCC+ VCC– + 8 VCC+ V Switch on-state current 10 10 10 mA Operating free-air temperature, TA 0 70 25 85 –55 125 °C POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 3
