Datasheet MUR105 - MUR1100 (MCC)
ManufacturerMCC
Description1 Amp Super Fast Recovery Rectifier50 to 1000 Volts
Pages / Page4 / 1 — MUR105. Micro Commercial Components. THRU. MUR1100. 1 Amp Super Fast. …
File Format / SizePDF / 369 Kb
MUR105. Micro Commercial Components. THRU. MUR1100. 1 Amp Super Fast. Recovery Rectifier. 50 to 1000 Volts. 1 of 4
Datasheet MUR105 - MUR1100 MCC
M C C TM omponents
MUR105
20736 Marilla Street Chatsworth
Micro Commercial Components THRU
MUR1100
Features • Halogen free available upon request by adding suffix "-HF" • Super Fast Switching Speed For High Efficiency • Marking:TypeNumber
1 Amp Super Fast
• Epoxy meets UL 94 V-0 flammability rating • Moisture Sensitivity Level 1
Recovery Rectifier
• Lead Free Finish/RoHS Compliant (Note1) ("P"Suffix designates Compliant. See ordering information)
50 to 1000 Volts
Maximum Ratings • Operating Temperature: -50°C to +150°C • Storage Temperature: -50°C to +150°C Maximum Maximum DC DO-41 MCC Recurrent Maximum Blocking Part Number Peak Reverse RMS Voltage Voltage Voltage MUR105 50V 35V 50V MUR110 100V 70V 100V MUR115 150V 105V 150V MUR120 200V 140V 200V MUR140 400V 280V 400V D MUR160 600V 420V 600V MUR180 800V 560V 800V MUR1100 1000V 700V 1000V Electrical Characteristics @ 25°C Unless Otherwise Specified A Cathode Average Forward IF(AV) 1 A TA = 55°C Mark Current B Peak Forward Surge IFSM 35A 8.3ms, half sine Current D Maximum Instantaneous Forward Voltage C MUR105-115 VF .975V IFM = 1.0A; MUR120-160 1.35V TA = 25°C MUR180-1100 1.75V Maximum DC Reverse Current At I DIMENSIONS R 5µA TA = 25°C Rated DC Blocking 50µA TA = 150°C INCHES MM Voltage DIM MIN MAX MIN MAX NOTE A .166 .205 4.10 5.20 Maximum Reverse B .080 .107 2.00 2.70 Recovery Time C .028 .034 .70 .90 D 1.000 --- 25.40 --- MUR105-120 Trr 45ns IF=0.5A, IR=1.0A, MUR140-160 60ns Irr=0.25A MUR180-1100 75ns Typical Junction Measured at C Capacitance J 20pF 1.0MHz, VR=4.0V Note: 1. High Temperature Solder Exemption Applied, see EU Directive Annex 7. www.mccsemi.com Revision: B
1 of 4
2013/01/01
