Datasheet MUR105 - MUR1100 (MCC) - 3
Manufacturer | MCC |
Description | 1 Amp Super Fast Recovery Rectifier50 to 1000 Volts |
Pages / Page | 4 / 3 — Micro Commercial Components. 3 of 4 |
File Format / Size | PDF / 369 Kb |
M C C MUR105 thru MUR110 TM
Figure 4 Typical Reverse Characteristics Figure 5 100 Peak Forward Surge Current 60 60 40 50 T 20 A=150 °C 40 10 30 6 Amps 20 4 10 2 TA=100 °C 0 µAmps 1 1 2 4 6 8 10 20 40 60 80100 .6 Cycles .4 Peak Forward Surge Current - Amperes versus Number Of Cycles At 60Hz - Cycles .2 .1 TA=25°C .06 .04 .02 .01 20 40 60 80 100 120 140 Volts Instantaneous Reverse Leakage Current - MicroAmperes versus Percent Of Rated Peak Reverse Voltage - Volts Figure 6 Reverse Recovery Time Characteristic And Test Circuit Diagram 50Ω 10Ω trr +0.5A 0 Pulse -0.25 25Vdc Generator Note 2 1Ω Oscilloscope -1.0 Note 1 1cm Notes: Set Time Base for 20/100ns/cm 1. Rise Time = 7ns max. Input impedance = 1 megohm, 22pF 2. Rise Time = 10ns max. Source impedance = 50 ohms 3. Resistors are non-inductive www.mccsemi.com Revision: B
3 of 4
2013/01/01
