Datasheet MAX4073T, MAX4073F, MAX4073H (Maxim) - 4
Manufacturer | Maxim |
Description | Low-Cost, SC70, Voltage-Output, High-Side Current-Sense Amplifier |
Pages / Page | 12 / 4 — MAX4073T/F/H. Low-Cost, SC70, Voltage-Output, High-Side Current-Sense … |
Revision | 1 |
File Format / Size | PDF / 370 Kb |
MAX4073T/F/H. Low-Cost, SC70, Voltage-Output, High-Side Current-Sense Amplifier. Typical Operating Characteristics
MAX4073T/F/H Low-Cost, SC70, Voltage-Output, High-Side Current-Sense Amplifier Typical Operating Characteristics
(VCC = +12V, VRS+ = +12V, VSENSE = 100mV, CL = 5pF, TA = +25°C, unless otherwise noted.)
SUPPLY CURRENT vs. SUPPLY CURRENT vs. SUPPLY CURRENT vs. SUPPLY VOLTAGE SUPPLY VOLTAGE TEMPERATURE
0.53 1.5 0.7 V 0.52 1.4 SENSE = 0 MAX4073H MAX4073H 0.6 VCC = +28V 0.51 MAX4073 toc01 1.3 MAX4073 toc02 MAX4073 toc03 0.50 MAX4073F 1.2 0.5 0.49 1.1 0.4 0.48 1.0 0.3 0.47 0.9 MAX4073F MAX4073T SUPPLY CURRENT (mA) 0.46 SUPPLY CURRENT (mA) 0.8 SUPPLY CURRENT (mA) 0.2 0.45 0.7 MAX4073T 0.1 0.44 0.6 VSENSE = 6.25mV VSENSE = 100mV 0.43 0.5 0 0 5 10 15 20 25 30 0 5 10 15 20 25 30 -50 -25 0 25 50 75 100 125 SUPPLY VOLTAGE (V) SUPPLY VOLTAGE (V) TEMPERATURE (˚C)
SUPPLY CURRENT vs. SUPPLY CURRENT vs. OUTPUT HIGH VOLTAGE VRS+ VOLTAGE VRS+ VOLTAGE (VCC - VOH) vs. TEMPERATURE
0.54 1.60 1.0 V V SENSE = 6.25mV SENSE = 100mV 1.50 VSENSE = 150mV 0.9 0.53 MAX4073H MAX4073H MAX4073 toc04 1.40 MAX4073 toc05 0.8 MAX4073 toc06 0.52 1.30 0.7 1.20 (V) 0.51 0.6 OH 1.10 0.5 - V 0.50 MAX4073F MAX4073F 1.00 V CC 0.4 SUPPLY CURRENT (mA) 0.49 SUPPLY CURRENT (mA) 0.90 0.3 0.80 MAX4073T 0.2 0.48 MAX4073T 0.70 0.1 0.47 0.60 0 0 5 10 15 20 25 30 0 5 10 15 20 25 30 -50 -25 0 25 50 75 100 125 VRS+ (V) VRS+ (V) TEMPERATURE (°C)
TOTAL OUTPUT ERROR vs. TOTAL OUTPUT ERROR TOTAL OUTPUT ERROR SUPPLY VOLTAGE vs. SUPPLY VOLTAGE vs. COMMON-MODE VOLTAGE
1.0 2.0 1.0 VSENSE = 100mV VSENSE = 6.25mV 0.8 MAX4073F 4073 toc07 1.5 0.5 0.6 MAX MAX4073 toc08 MAX4073 toc09 1.0 0 0.4 MAX4073H 0.2 0.5 -0.5 0 0 -1.0 -0.2 -0.5 -1.5 -0.4 TOTAL OUTPUT ERROR (%) MAX4073T TOTAL OUTPUT ERROR (%) -1.0 TOTAL OUTPUT ERROR (%) -2.0 -0.6 -0.8 -1.5 -2.5 -1.0 -2.0 -3.0 0 5 10 15 20 25 30 0 5 10 15 20 25 30 0 5 10 15 20 25 30 SUPPLY VOLTAGE (V) SUPPLY VOLTAGE (V) COMMON-MODE VOLTAGE (V)
4
Maxim Integrated
