Datasheet AD8221 (Analog Devices) - 10
DescriptionPrecision Instrumentation Amplifier
Pages / Page25 / 10 — AD8221. –IN. +VS. VOUT. REF. +IN. –VS. TOP VIEW. (Not to Scale). Table 5. …
RevisionC
File Format / SizePDF / 643 Kb
AD8221. –IN. +VS. VOUT. REF. +IN. –VS. TOP VIEW. (Not to Scale). Table 5. Pin Function Descriptions Pin No. Mnemonic. Description
AD8221 –IN +VS VOUT REF +IN –VS TOP VIEW (Not to Scale) Table 5 Pin Function Descriptions Pin No Mnemonic Description
AD8221 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS
AD8221 –IN 1 8 +VS RG 2 7 VOUT RG 3 6 REF +IN 4 5 –VS
3 0 -1
TOP VIEW
9 4
(Not to Scale)
1 3 0 Figure 3. Pin Configuration
Table 5. Pin Function Descriptions Pin No. Mnemonic Description
1 −IN Negative Input Terminal. 2 R Gain Setting Terminal. Place resistor across the R pins to set the gain. G = 1 + (49.4 kΩ/R ). G G G 3 R Gain Setting Terminal. Place resistor across the R pins to set the gain. G = 1 + (49.4 kΩ/R ). G G G 4 +IN Positive Input Terminal. 5 −V Negative Power Supply Terminal. S 6 REF Reference Voltage Terminal. Drive this terminal with a low impedance voltage source to level-shift the output. 7 V Output Terminal. OUT 8 +V Positive Power Supply Terminal. S Rev. C | Page 9 of 24
