Datasheet AD8138 (Analog Devices) - 2
DescriptionLow Distortion Differential ADC Driver
Pages / Page25 / 2 — AD8138* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionG
File Format / SizePDF / 527 Kb
AD8138* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE DESIGNS. EVALUATION KITS
AD8138* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE DESIGNS EVALUATION KITS
View a parametric search of comparable parts. • CN0040 • CN0041
EVALUATION KITS
• CN0061 • Universal Evaluation Board for Single Differential Amplifiers
REFERENCE MATERIALS Product Selection Guide DOCUMENTATION
• High Speed Amplifiers Selection Table
Application Notes Technical Articles
• AN-0990: Terminating a Differential Amplifier in Single- • Maximize Performance When Driving Differential ADCs Ended Input Applications
Tutorials
• AN-0992: Active Filter Evaluation Board for Differential Amplifiers • MT-075: Differential Drivers for High Speed ADCs Overview • AN-1026: High Speed Differential ADC Driver Design Considerations • MT-076: Differential Driver Analysis • AN-1363: Meeting Biasing Requirements of Externally • MT-218: Multiple Feedback Band-Pass Design Example Biased RF/Microwave Amplifiers with Active Bias • MT-230: Noise Considerations in High Speed Converter Controllers Signal Chains • AN-584: Using the AD813X Differential Amplifier • AN-589: Ways to Optimize the Performance of a
DESIGN RESOURCES
Difference Amplifier • AD8138 Material Declaration • AN-649: Using the Analog Devices Active Filter Design • PCN-PDN Information Tool • Quality And Reliability
Data Sheet
• Symbols and Footprints • AD8138-DSCC: Military Data Sheet • AD8138-EP: Enhanced Product Data Sheet
DISCUSSIONS
• AD8138: Low Distortion Differential ADC Driver Data View all AD8138 EngineerZone Discussions. Sheet
User Guides SAMPLE AND BUY
• UG-474: Evaluation Board for Differential Amplifiers Visit the product page to see pricing options. Offered in 8-Lead SOIC Packages • UG-888: Evaluation Board for Differential Amplifiers Offered in 8-Lead MSOP Packages
TECHNICAL SUPPORT
Submit a technical question or find your regional support
TOOLS AND SIMULATIONS
number. • ADI DiffAmpCalc™
DOCUMENT FEEDBACK
• AD8138 SPICE Macro-Model Submit feedback for this data sheet.
Document Outline FEATURES APPLICATIONS PIN CONFIGURATION TYPICAL APPLICATION CIRCUIT GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±DIN TO ±OUT SPECIFICATIONS VOCM TO ±OUT SPECIFICATIONS ±DIN TO ±OUT SPECIFICATIONS VOCM TO ±OUT SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Maximum Power Dissipation ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS OPERATIONAL DESCRIPTION DEFINITION OF TERMS THEORY OF OPERATION ANALYZING AN APPLICATION CIRCUIT SETTING THE CLOSED-LOOP GAIN ESTIMATING THE OUTPUT NOISE VOLTAGE THE IMPACT OF MISMATCHES IN THE FEEDBACK NETWORKS CALCULATING THE INPUT IMPEDANCE OF AN APPLICATION INPUT COMMON-MODE VOLTAGE RANGE IN SINGLE-SUPPLY APPLICATIONS SETTING THE OUTPUT COMMON-MODE VOLTAGE DRIVING A CAPACITIVE LOAD LAYOUT, GROUNDING, AND BYPASSING BALANCED TRANSFORMER DRIVER HIGH PERFORMANCE ADC DRIVING 3 V OPERATION OUTLINE DIMENSIONS ORDERING GUIDE
