Datasheet AD8138 (Analog Devices) - 10
DescriptionLow Distortion Differential ADC Driver
Pages / Page25 / 10 — Data Sheet. AD8138. TYPICAL PERFORMANCE CHARACTERISTICS. IN = 0.2V p-p. …
RevisionG
File Format / SizePDF / 527 Kb
Data Sheet. AD8138. TYPICAL PERFORMANCE CHARACTERISTICS. IN = 0.2V p-p. IN = 2V p-p. F = 0pF. VS = +5V. S = +5V. N (. VS = ±5V. S = ±5V. 100
Data Sheet AD8138 TYPICAL PERFORMANCE CHARACTERISTICS IN = 0.2V p-p IN = 2V p-p F = 0pF VS = +5V S = +5V N ( VS = ±5V S = ±5V 100
link to page 16
Unless otherwise noted, Gain = 1, RG = RF = RL, dm = 499 V, TA = 25°C; refer to Figure 39 for test setup.
6 6 V V IN = 0.2V p-p IN = 2V p-p C C F = 0pF F = 0pF 3 3 V VS = +5V S = +5V 0 0 B) B) d d N ( VS = ±5V N ( V AI AI S = ±5V G –3 G –3 –6 –6 –9 –9 1 10 100 1000
005
1 10 100 1000
008
FREQUENCY (MHz) FREQUENCY (MHz)
01073- 01073- Figure 5. Small Signal Frequency Response Figure 8. Large Signal Frequency Response
6 6 VS = ±5V VIN = 2V p-p VIN = 0.2V p-p VS = ±5V 3 3 CF = 0pF CF = 0pF 0 0 B) B) d d N ( C N ( AI F = 1pF AI CF = 1pF G G –3 –3 –6 –6 –9 –9 1 10 100 1000
006
1 10 100 1000
009
01073- 01073- Figure 6. Small Signal Frequency Response Figure 9. Large Signal Frequency Response
0.5 30 V VS = ±5V S = ±5V V CF = 0pF IN = 0.2V p-p VOUT, dm = 0.2V p-p 0.3 RG = 499Ω C G = 10, R F = 0pF 20 F = 4.99kΩ G = 5, RF = 2.49kΩ 0.1 B) B) d d N ( N ( 10 AI AI G = 2, R G F = 1kΩ –0.1 G CF = 1pF G = 1, RF = 499Ω 0 –0.3 –0.5 –10 1 10 100
007
1 10 100 1000
010
01073- 01073- Figure 7. 0.1 dB Flatness vs. Frequency Figure 10. Small Signal Frequency Response for Various Gains Rev. G | Page 9 of 24 Document Outline FEATURES APPLICATIONS PIN CONFIGURATION TYPICAL APPLICATION CIRCUIT GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±DIN TO ±OUT SPECIFICATIONS VOCM TO ±OUT SPECIFICATIONS ±DIN TO ±OUT SPECIFICATIONS VOCM TO ±OUT SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Maximum Power Dissipation ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS OPERATIONAL DESCRIPTION DEFINITION OF TERMS THEORY OF OPERATION ANALYZING AN APPLICATION CIRCUIT SETTING THE CLOSED-LOOP GAIN ESTIMATING THE OUTPUT NOISE VOLTAGE THE IMPACT OF MISMATCHES IN THE FEEDBACK NETWORKS CALCULATING THE INPUT IMPEDANCE OF AN APPLICATION INPUT COMMON-MODE VOLTAGE RANGE IN SINGLE-SUPPLY APPLICATIONS SETTING THE OUTPUT COMMON-MODE VOLTAGE DRIVING A CAPACITIVE LOAD LAYOUT, GROUNDING, AND BYPASSING BALANCED TRANSFORMER DRIVER HIGH PERFORMANCE ADC DRIVING 3 V OPERATION OUTLINE DIMENSIONS ORDERING GUIDE
