Datasheet ADA4610-1, ADA4610-2, ADA4610-4 (Analog Devices) - 9
DescriptionLow Noise, Precision, Rail-to-Rail Output, JFET Single Op Amp
Pages / Page25 / 9 — Data Sheet. ADA4610-1/ADA4610-2/ADA4610-4. –IN A 1. 12 –IN D. +IN A 2. …
RevisionI
File Format / SizePDF / 761 Kb
Data Sheet. ADA4610-1/ADA4610-2/ADA4610-4. –IN A 1. 12 –IN D. +IN A 2. ADA4610-4. 11 +IN D. TOP. V+ 3. 10 V–. VIEW. OUT A 1. 14 OUT D. +IN B 4
Data Sheet ADA4610-1/ADA4610-2/ADA4610-4 –IN A 1 12 –IN D +IN A 2 ADA4610-4 11 +IN D TOP V+ 3 10 V– VIEW OUT A 1 14 OUT D +IN B 4
Data Sheet ADA4610-1/ADA4610-2/ADA4610-4 A D C T T I U U CI N O O N 61 51 41 31 –IN A 1 12 –IN D +IN A 2 ADA4610-4 11 +IN D TOP V+ 3 10 V– VIEW OUT A 1 14 OUT D +IN B 4 9 +IN C –IN A 2 13 –IN D +IN A 3 12 +IN D ADA4610-4 5 6 7 8 V+ B B C C 4 TOP VIEW 11 V– N T I T N U U I +IN B (Not to Scale) 5 10 +IN C O O –IN B NOTES 6 9 –IN C
6
1. NIC = NOT INTERNALLY CONNECTED.
7 10 -10
OUT B 7 8 OUT C
6-
2.THE EXPOSED PAD MUST BE CONNECTED TO V–.
64 646 09 09 Figure 7. ADA4610-4 Pin Configuration, 14-Lead SOIC (R Suffix) Figure 8. ADA4610-4 Pin Configuration, 16-Lead LFCSP (CP Suffix)
Table 9. ADA4610-4 Pi n Function Descriptions, 14-Lead SOIC and 16-Lead LFCSP Pin No. 14-Lead SOIC 16-Lead LFCSP Mnemonic Description
1 15 OUT A Output Channel A. 2 1 −IN A Inverting Input Channel A. 3 2 +IN A Noninverting Input Channel A. 4 3 V+ Positive Supply Voltage. 5 4 +IN B Noninverting Input Channel B. 6 5 −IN B Inverting Input Channel B. 7 6 OUT B Output Channel B. 8 7 OUT C Output Channel C. 9 8 −IN C Inverting Input Channel C. 10 9 +IN C Noninverting Input Channel C. 11 10 V− Negative Supply Voltage. 12 11 +IN D Noninverting Input Channel D. 13 12 −IN D Inverting Input Channel D. 14 14 OUT D Output Channel D. Not applicable 13, 16 NIC Not Internally Connected. Not applicable EPAD Exposed Pad. The exposed pad must be connected to V−. Rev. G | Page 9 of 25 Document Outline FEATURES APPLICATIONS PIN CONFIGURATION GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS COMPARATIVE VOLTAGE AND VARIABLE VOLTAGE GRAPHS FUNCTIONAL DESCRIPTION APPLICATIONS INFORMATION INPUT OVERVOLTAGE PROTECTION PEAK DETECTOR CURRENT TO VOLTAGE (I TO V) CONVERSION APPLICATIONS Photodiode Circuits COMPARATOR OPERATION OUTLINE DIMENSIONS ORDERING GUIDE
