Datasheet ADA4610-1, ADA4610-2, ADA4610-4 (Analog Devices) - 10
Description | Low Noise, Precision, Rail-to-Rail Output, JFET Single Op Amp |
Pages / Page | 25 / 10 — ADA4610-1/ADA4610-2/ADA4610-4. Data Sheet. TYPICAL PERFORMANCE … |
Revision | I |
File Format / Size | PDF / 761 Kb |
ADA4610-1/ADA4610-2/ADA4610-4. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 400. SOIC. 350. 300. 250. CHANNE 200. CHANNE. 200. R O. 150
ADA4610-1/ADA4610-2/ADA4610-4 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS
TA = 25°C, unless otherwise noted.
400 400 SOIC SOIC 350 350 300 300 S S L L 250 250 CHANNE 200 CHANNE F 200 F R O R O 150 150 BE BE NUM 100 NUM 100 50 50 0 0 –1000 –800 –600 –400 –200 0 200 400 600 800 1000 1200
003
006
OFFSET VOLTAGE (µV) OFFSET VOLTAGE (µV)
09646- 09646- Figure 9. Input Offset Voltage Distribution, VSY = ±5 V Figure 12. Input Offset Voltage Distribution, VSY = ±15 V
350 350 SOIC SOIC 300 300 S 250 S L 250 L 200 200 CHANNE CHANNE F F 150 R O 150 R O BE BE 100 100 NUM NUM 50 50 0 0 0 5 0 5 0 5 0 5 0 5 0 5 0 5 0 5 0 5 0 5 0 5 0 5 0 5 0 5 0 5 0 5 0 5 0 5 0 5 0 5 0 5 0 5 0. 1. 1. 2. 2. 3. 3. 4. 4. 5. 5. 6. 6. 7. 7. 8. 8. 9. 9.
004
007
10. 10. 10. 10. TCVOS (µV/°C) TCV
09646-
OS (µV/°C)
09646- Figure 10. Input Offset Voltage Drift (TCVOS) Distribution, VSY = ±5 V Figure 13. TCVOS Distribution, VSY = ±15 V
1500 1500 1000 1000 V) V) E (µ E (u G 500 G 500 A A LT LT O O T V 0 T V 0 E E –500 T OFFS –500 T OFFS U U P MEAN P MEAN IN MEAN + 3σ IN MEAN + 3σ –1000 MEAN – 3σ –1000 MEAN – 3σ –1500 –1500
005
–5 –4 –3 –2 –1 0 1 2 3 4 5 –15 –10 –5 0 5 10 15
008
VCM (V)
09646-
VCM (V)
09646- Figure 11. Input Offset Voltage vs. Common-Mode Input Voltage (VCM), Figure 14. Input Offset Voltage vs. Input Common-Mode Voltage (VCM), VSY = ±5 V, RL = ∞ VSY = ±15 V, RL = ∞ Rev. G | Page 10 of 25 Document Outline FEATURES APPLICATIONS PIN CONFIGURATION GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS COMPARATIVE VOLTAGE AND VARIABLE VOLTAGE GRAPHS FUNCTIONAL DESCRIPTION APPLICATIONS INFORMATION INPUT OVERVOLTAGE PROTECTION PEAK DETECTOR CURRENT TO VOLTAGE (I TO V) CONVERSION APPLICATIONS Photodiode Circuits COMPARATOR OPERATION OUTLINE DIMENSIONS ORDERING GUIDE
