Datasheet AD745 (Analog Devices) - 3
DescriptionUltralow Noise, High Speed, BiFET Op Amp
Pages / Page13 / 3 — AD745–SPECIFICATIONS. AD745 ELECTRICAL CHARACTERISTICS (@ +25. C and. 15 …
RevisionD
File Format / SizePDF / 373 Kb
AD745–SPECIFICATIONS. AD745 ELECTRICAL CHARACTERISTICS (@ +25. C and. 15 V dc, unless otherwise noted.). Model. AD745J. AD745K
AD745–SPECIFICATIONS AD745 ELECTRICAL CHARACTERISTICS (@ +25 C and 15 V dc, unless otherwise noted.) Model AD745J AD745K
AD745–SPECIFICATIONS AD745 ELECTRICAL CHARACTERISTICS (@ +25 C and 15 V dc, unless otherwise noted.) Model AD745J AD745K Conditions Min Typ Max Min Typ Max Unit
INPUT OFFSET VOLTAGE1 Initial Offset 0.25 1.0 0.1 0.5 mV Initial Offset TMIN to TMAX 1.5 1.0 mV vs. Temp. TMIN to TMAX 2 2 µV/°C vs. Supply (PSRR) 12 V to 18 V2 90 96 100 106 dB vs. Supply (PSRR) TMIN to TMAX 88 98 105 dB INPUT BIAS CURRENT3 Either Input VCM = 0 V 150 400 150 250 pA Either Input @ TMAX VCM = 0 V 8.8 5.5 nA Either Input VCM = +10 V 250 600 250 400 pA Either Input, VS = ± 5 V VCM = 0 V 30 200 30 125 pA INPUT OFFSET CURRENT VCM = 0 V 40 150 30 75 pA Offset Current @ TMAX VCM = 0 V 2.2 1.1 nA FREQUENCY RESPONSE Gain BW, Small Signal G = –4 20 20 MHz Full Power Response VO = 20 V p-p 120 120 kHz Slew Rate G = –4 12.5 12.5 V/µs Settling Time to 0.01% 5 5 µs Total Harmonic f = 1 kHz Distortion4 G = –4 0.0002 0.0002 % INPUT IMPEDANCE Differential 1 × 1010储20 1 × 1010储20 Ω储pF Common Mode 3 × 1011储18 3 × 1011储18 Ω储pF INPUT VOLTAGE RANGE Differential5 ±20 ± 20 V Common-Mode Voltage +13.3, –10.7 +13.3, –10.7 V Over Max Operating Range6 –10 +12 –10 +12 V Common-Mode Rejection Ratio VCM = ± 10 V 80 95 90 102 dB TMIN to TMAX 78 88 dB INPUT VOLTAGE NOISE 0.1 to 10 Hz 0.38 0.38 1.0 µV p-p f = 10 Hz 5.5 5.5 10.0 nV/√Hz f = 100 Hz 3.6 3.6 6.0 nV/√Hz f = 1 kHz 3.2 5.0 3.2 5.0 nV/√Hz f = 10 kHz 2.9 4.0 2.9 4.0 nV/√Hz INPUT CURRENT NOISE f = 1 kHz 6.9 6.9 fA/√Hz OPEN LOOP GAIN VO = ± 10 V RLOAD ≥ 2 kΩ 1000 4000 2000 4000 V/mV TMIN to TMAX 800 1800 V/mV RLOAD = 600 Ω 1200 1200 V/mV OUTPUT CHARACTERISTICS Voltage RLOAD ≥ 600 Ω +13, –12 +13, –12 V RLOAD ≥ 600 Ω +13.6, –12.6 +13.6, –12.6 V TMIN to TMAX +12, –10 +12, –10 V RLOAD ≥ 2 kΩ ±12 +13.8, –13.1 +13.8, –13.1 V Current Short Circuit 20 40 20 40 mA POWER SUPPLY Rated Performance ±15 ± 15 V Operating Range ±4.8 ± 18 ± 4.8 ± 18 V Quiescent Current 8 10.0 8 10.0 mA TRANSISTOR COUNT # of Transistors 50 50 NOTES 1Input offset voltage specifications are guaranteed after five minutes of operations at TA = 25°C. 2Test conditions: +VS = 15 V, –VS = 12 V to 18 V and +VS = 12 V to +18 V, –VS = 15 V. 3Bias current specifications are guaranteed maximum at either input after five minutes of operation at TA = 25°C. For higher temperature, the current doubles every 10°C. 4Gain = –4, RL = 2 kΩ, CL = 10 pF. 5Defined as voltage between inputs, such that neither exceeds ± 10 V from common. 6The AD745 does not exhibit an output phase reversal when the negative common-mode limit is exceeded. All min and max specifications are guaranteed. Specifications subject to change without notice. –2– REV. D
