Datasheet AD8002 (Analog Devices)
Description | Dual 600 MHz, 50 mW Current Feedback Amplifier |
Pages / Page | 22 / 1 — Dual 600 MHz, 50 mW. Current Feedback Amplifier. Data Sheet. AD8002. … |
Revision | E |
File Format / Size | PDF / 593 Kb |
Dual 600 MHz, 50 mW. Current Feedback Amplifier. Data Sheet. AD8002. FEATURES. PIN CONNECTION BLOCK DIAGRAM
Dual 600 MHz, 50 mW Current Feedback Amplifier Data Sheet AD8002 FEATURES PIN CONNECTION BLOCK DIAGRAM Excellent video specifications (RL = 150 Ω, G = +2) Gain flatness: 0.1 dB to 60 MHz OUT1 1 8 V+ Differential gain error: 0.01% –IN1 2 7 OUT2 Differential phase error: 0.02° Low power +IN1 3 6 –IN2 Maximum power supply current (50 mW): 5.0 mA/amp V– 4 5 +IN2
001
High speed and fast settling AD8002
01044-
−3 dB bandwidth (G = +1): 600 MHz
Figure 1.
−3 dB bandwidth (G = +2): 500 MHz Slew rate: 1200 V/µs Settling time to 0.1%: 16 ns Low distortion THD at fC = 5 MHz: −65 dBc Third-order intercept at f1 = 10 MHz: 33 dBm SFDR at f = 5 MHz: −66 dB Crosstalk at f = 5 MHz: −60 dB High output drive Over 70 mA output current Drives up to eight back terminated 75 Ω loads (four loads/side) while maintaining good differential
The AD8002 offers a low power of 5.0 mA/amp maximum
gain/phase performance (0.01%/0.17°)
(VS = ±5 V) and can run on a single 12 V power supply, yet is
Available in 8-lead SOIC and MSOP packages
capable of delivering over 70 mA of load current. It is offered
in 8-lead SOIC and MSOP packages. These features make this amplifier ideal for portable and battery-powered applications
Analog-to-digital drivers
where size and power are critical.
Video line drivers Differential line drivers
The bandwidth of 600 MHz along with 1200 V/µs of slew rate
Professional cameras
make the AD8002 useful in many general-purpose high speed
Video switchers
applications where dual power supplies of up to ±6 V and single
Special effects
supplies from 6 V to 12 V are needed. The AD8002 is available
RF receivers
in the industrial temperature range of −40°C to +85°C.
GENERAL DESCRIPTION
The AD8002 is a dual, low power, high speed amplifier designed to operate on ±5 V supplies. The AD8002 features
SIDE 1
unique transimpedance linearization circuitry, which allows the
G = +2 1V STEP
AD8002 to drive video loads with excellent differential gain and phase performance on only 50 mW of power per amplifier. The AD8002 is a current feedback amplifier and features gain flatness of 0.1 dB to 60 MHz while offering differential gain and phase error of 0.01% and 0.02°, which makes the AD8002 ideal for professional video electronics such as cameras and video
SIDE 2
switchers. Additionally, the low distortion and fast settling of 003
200mV 5ns
the AD8002 make it ideal for buffer high speed analog-to- 01044- digital converters (ADCs). Figure 2. 1 V Step Response, G = +1
Rev. E Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2015 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications General Description Pin Connection Block Diagram Table of Contents Revision History Specifications Absolute Maximum Ratings Maximum Power Dissipation ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Test Circuits Theory of Operation Choice of Feedback and Gain Resistors Printed Circuit Board (PCB) Layout Considerations Power Supply Bypassing DC Errors and Noise Driving Capacitive Loads Communications Operation as a Video Line Driver Driving ADCs Single-Ended-to-Differential Driver Using an AD8002 Applications Information Layout Considerations Outline Dimensions Ordering Guide
