AD8002* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017COMPARABLE PARTSREFERENCE MATERIALS View a parametric search of comparable parts. Product Selection Guide • High Speed Amplifiers Selection Table EVALUATION KITSTutorials • Universal Evaluation Board for Dual High Speed • MT-034: Current Feedback (CFB) Op Amps Operational Amplifiers • MT-051: Current Feedback Op Amp Noise Considerations • MT-057: High Speed Current Feedback Op Amps DOCUMENTATION • MT-059: Compensating for the Effects of Input Application Notes Capacitance on VFB and CFB Op Amps Used in Current-to- • AN-356: User's Guide to Applying and Measuring Voltage Converters Operational Amplifier Specifications • AN-649: Using the Analog Devices Active Filter Design DESIGN RESOURCES Tool • AD8002 Material Declaration • AN-692: Universal Precision Op Amp Evaluation Board • PCN-PDN Information Data Sheet • Quality And Reliability • AD8002: Dual 600 MHz, 50 mW Current Feedback • Symbols and Footprints Amplifier Data Sheet User GuidesDISCUSSIONS • UG-128: Universal Evaluation Board for Dual High Speed Op Amps in SOIC Packages View all AD8002 EngineerZone Discussions. • UG-886: Universal Evaluation Board for Dual High Speed Op Amps Offered in 8-Lead MSOP SAMPLE AND BUY Visit the product page to see pricing options. TOOLS AND SIMULATIONS • AD8002 SPICE Macro Model TECHNICAL SUPPORT Submit a technical question or find your regional support number. DOCUMENT FEEDBACK Submit feedback for this data sheet. This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified. Document Outline Features Applications General Description Pin Connection Block Diagram Table of Contents Revision History Specifications Absolute Maximum Ratings Maximum Power Dissipation ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Test Circuits Theory of Operation Choice of Feedback and Gain Resistors Printed Circuit Board (PCB) Layout Considerations Power Supply Bypassing DC Errors and Noise Driving Capacitive Loads Communications Operation as a Video Line Driver Driving ADCs Single-Ended-to-Differential Driver Using an AD8002 Applications Information Layout Considerations Outline Dimensions Ordering Guide
