Datasheet ATtiny13, ATtiny13V - Summary (Microchip)
Manufacturer | Microchip |
Description | 8-bit AVR Microcontroller with 1K Bytes In-System Programmable Flash |
Pages / Page | 22 / 1 — Features. High Performance, Low Power AVR. 8-Bit Microcontroller. … |
Revision | Rev. 08-01-2010 |
File Format / Size | PDF / 574 Kb |
Features. High Performance, Low Power AVR. 8-Bit Microcontroller. Advanced RISC Architecture
Features
Advanced RISC Architecture – 120 Powerful Instructions – Most Single Clock Cycle Execution – 32 x 8 General Purpose Working Registers – Fully Static Operation – Up to 20 MIPS Througput at 20 MHz
High Endurance Non-volatile Memory segments – 1K Bytes of In-System Self-programmable Flash program memory – 64 Bytes EEPROM 8-bit – 64 Bytes Internal SRAM Microcontroller – Write/Erase cyles: 10,000 Flash/100,000 EEPROM – Data retention: 20 years at 85°C/100 years at 25°C (see page 6) with 1K Bytes – Programming Lock for Self-Programming Flash & EEPROM Data Security
Peripheral Features In-System – One 8-bit Timer/Counter with Prescaler and Two PWM Channels – 4-channel, 10-bit ADC with Internal Voltage Reference Programmable – Programmable Watchdog Timer with Separate On-chip Oscillator – On-chip Analog Comparator Flash
Special Microcontroller Features – debugWIRE On-chip Debug System – In-System Programmable via SPI Port ATtiny13 – External and Internal Interrupt Sources – Low Power Idle, ADC Noise Reduction, and Power-down Modes ATtiny13V – Enhanced Power-on Reset Circuit – Programmable Brown-out Detection Circuit – Internal Calibrated Oscillator
I/O and Packages Summary – 8-pin PDIP/SOIC: Six Programmable I/O Lines – 20-pad MLF: Six Programmable I/O Lines
Operating Voltage: – 1.8 - 5.5V for ATtiny13V – 2.7 - 5.5V for ATtiny13
Speed Grade – ATtiny13V: 0 - 4 MHz @ 1.8 - 5.5V, 0 - 10 MHz @ 2.7 - 5.5V – ATtiny13: 0 - 10 MHz @ 2.7 - 5.5V, 0 - 20 MHz @ 4.5 - 5.5V
Industrial Temperature Range
Low Power Consumption – Active Mode: • 1 MHz, 1.8V: 240 µA – Power-down Mode: • < 0.1 µA at 1.8V
Rev. 2535JS–AVR–08/10 Document Outline Features 1. Pin Configurations 1.1 Pin Descriptions 1.1.1 VCC 1.1.2 GND 1.1.3 Port B (PB5:PB0) 1.1.4 RESET 2. Overview 2.1 Block Diagram 3. General Information 3.1 Resources 3.2 Code Examples 3.3 Data Retention 4. Register Summary 5. Instruction Set Summary 6. Ordering Information 7. Packaging Information 7.1 8P3 7.2 8S2 7.3 S8S1 7.4 20M1 7.5 10M1 8. Errata 8.1 ATtiny13 Rev. D 8.2 ATtiny13 Rev. C 8.3 ATtiny13 Rev. B 8.3.1 Wrong values read after Erase Only operation 8.3.2 High Voltage Serial Programming Flash, EEPROM, Fuse and Lock Bits may fail 8.3.3 Device may lock for further programming 8.3.4 debugWIRE communication not blocked by lock-bits 8.3.5 Watchdog Timer Interrupt disabled 8.3.6 EEPROM can not be written below 1.9 Volt 8.4 ATtiny13 Rev. A 9. Datasheet Revision History 9.1 Rev. 2535J-08/10 9.2 Rev. 2535I-05/08 9.3 Rev. 2535H-10/07 9.4 Rev. 2535G-01/07 9.5 Rev. 2535F-04/06 9.6 Rev. 2535E-10/04 9.7 Rev. 2535D-04/04 9.8 Rev. 2535C-02/04 9.9 Rev. 2535B-01/04 9.10 Rev. 2535A-06/03
