Datasheet ATtiny13, ATtiny13V - Summary (Microchip) - 2
Manufacturer | Microchip |
Description | 8-bit AVR Microcontroller with 1K Bytes In-System Programmable Flash |
Pages / Page | 22 / 2 — 1. Pin Configurations. Figure 1-1. 8-PDIP/SOIC. 20-QFN/MLF. 10-QFN/MLF. … |
Revision | Rev. 08-01-2010 |
File Format / Size | PDF / 574 Kb |
1. Pin Configurations. Figure 1-1. 8-PDIP/SOIC. 20-QFN/MLF. 10-QFN/MLF. ATtiny13
1. Pin Configurations Figure 1-1.
Pinout ATtiny13/ATtiny13V
8-PDIP/SOIC
(PCINT5/RESET/ADC0/dW) PB5 1 8 VCC (PCINT3/CLKI/ADC3) PB3 2 7 PB2 (SCK/ADC1/T0/PCINT2) (PCINT4/ADC2) PB4 3 6 PB1 (MISO/AIN1/OC0B/INT0/PCINT1) GND 4 5 PB0 (MOSI/AIN0/OC0A/PCINT0)
20-QFN/MLF
DNC DNC DNC DNC DNC 20 19 18 17 16 (PCINT5/RESET/ADC0/dW) PB5 1 15 VCC (PCINT3/CLKI/ADC3) PB3 2 14 PB2 (SCK/ADC1/T0/PCINT2) DNC 3 13 DNC DNC 4 12 PB1 (MISO/AIN1/OC0B/INT0/PCINT1) (PCINT4/ADC2) PB4 5 11 PB0 (MOSI/AIN0/OC0A/PCINT0) 6 7 8 9 10 DNC DNC GND DNC DNC NOTE: Bottom pad should be soldered to ground. DNC: Do Not Connect
10-QFN/MLF
(PCINT5/RESET/ADC0/dW) PB5 1 10 VCC (PCINT3/CLKI/ADC3) PB3 2 9 PB2 (SCK/ADC1/T0/PCINT2) DNC 3 8 DNC (PCINT4/ADC2) PB4 4 7 PB1 (MISO/AIN1/OC0B/INT0/PCINT1) GND 5 6 PB0 (MOSI/AIN0/OC0A/PCINT0) NOTE: Bottom pad should be soldered to ground. DNC: Do Not Connect
2 ATtiny13
2535JS–AVR–08/10 Document Outline Features 1. Pin Configurations 1.1 Pin Descriptions 1.1.1 VCC 1.1.2 GND 1.1.3 Port B (PB5:PB0) 1.1.4 RESET 2. Overview 2.1 Block Diagram 3. General Information 3.1 Resources 3.2 Code Examples 3.3 Data Retention 4. Register Summary 5. Instruction Set Summary 6. Ordering Information 7. Packaging Information 7.1 8P3 7.2 8S2 7.3 S8S1 7.4 20M1 7.5 10M1 8. Errata 8.1 ATtiny13 Rev. D 8.2 ATtiny13 Rev. C 8.3 ATtiny13 Rev. B 8.3.1 Wrong values read after Erase Only operation 8.3.2 High Voltage Serial Programming Flash, EEPROM, Fuse and Lock Bits may fail 8.3.3 Device may lock for further programming 8.3.4 debugWIRE communication not blocked by lock-bits 8.3.5 Watchdog Timer Interrupt disabled 8.3.6 EEPROM can not be written below 1.9 Volt 8.4 ATtiny13 Rev. A 9. Datasheet Revision History 9.1 Rev. 2535J-08/10 9.2 Rev. 2535I-05/08 9.3 Rev. 2535H-10/07 9.4 Rev. 2535G-01/07 9.5 Rev. 2535F-04/06 9.6 Rev. 2535E-10/04 9.7 Rev. 2535D-04/04 9.8 Rev. 2535C-02/04 9.9 Rev. 2535B-01/04 9.10 Rev. 2535A-06/03
