Datasheet ATtiny4, ATtiny5, ATtiny9, ATiny10. Summary Datasheet (Microchip) - 8
ManufacturerMicrochip
DescriptionAtmel 8-bit AVR Microcontroller with 512/1024 Bytes In-System Programmable Flash
Pages / Page17 / 8 — 2.4. ATtiny10. Supply Voltage. Speed (1). Temperature. Package (2). …
File Format / SizePDF / 341 Kb
2.4. ATtiny10. Supply Voltage. Speed (1). Temperature. Package (2). Ordering Code (3). Note: . Table 2-4. Package Type
2.4 ATtiny10 Supply Voltage Speed (1) Temperature Package (2) Ordering Code (3) Note:  Table 2-4. Package Type
2.4. ATtiny10 Supply Voltage Speed (1) Temperature Package (2) Ordering Code (3)
1.8 – 5.5V 12MHz Industrial 6ST1 ATTINY10-TSUR(5) ATTINY10-TSHR(6)(7) (-40°C to 85°C) (4) 8MA4 ATTINY10-MAHR (7) 10MHz Extended 6ST1 ATTINY10-TSFR(5) ATTINY10-TS8R (6)(7) (-40°C to 125°C) (8)
Note: 
1. For speed vs. supply voltage, see section Speed. 2. All packages are Pb-free, halide-free and fully green and they comply with the European directive for Restriction of Hazardous Substances (RoHS). NiPdAu finish. 3. Tape and reel. 4. Can also be supplied in wafer form. Contact your local sales office for ordering information and minimum quantities. 5. Marking details: – Top mark 1st line: ddddTY – Top mark 2nd line: wwxxx dddd= device, special code T= Type Y= Year last digit ww= calendar workweek xxx = trace code 6. Not recommended for new designs.TPUBSTINY-216 7. Top/bottomside markings: – Top: T10
x
, where
x
= die revision – Bottom: z
H
zzz or z
8
zzz, where
H
= (-40°C to 85°C), and
8
= (-40°C to 125°C) 8. For typical and Electrical characteristics for this device please consult Appendix A, ATtiny4/5/9/10 Specification at 125°C.
6ST1 6-lead, 2.90 x 1.60 mm Plastic Small Outline Package (SOT23) 8MA4 8-pad, 2 x 2 x 0.6 mm Plastic Ultra Thin Dual Flat No Lead (UDFN) Atmel ATtiny4 / ATtiny5 / ATtiny9 / ATiny10 [DATASHEET] 8 Atmel-8127H-ATiny4/ ATiny5 /ATiny9/ ATiny10_Datasheet_Summary-11/2016 Document Outline Introduction Feature Table of Contents 1. Pin Configurations 1.1. Pin Descriptions 1.1.1. VCC 1.1.2. GND 1.1.3. Port B (PB[3:0]) 1.1.4. RESET 2. Ordering Information 2.1. ATtiny4 2.2. ATtiny5 2.3. ATtiny9 2.4. ATtiny10 3. Overview 3.1. Block Diagram 3.1.1. Description 3.2. Comparison of ATtiny4, ATtiny5, ATtiny9 and ATtiny10 4. General Information 4.1. Resources 4.2. Data Retention 4.3. About Code Examples 4.4. Capacitive Touch Sensing 4.4.1. QTouch Library 5. Packaging Information 5.1. 6ST1 5.2. 8MA4 6. Errata 6.1. ATtiny4 6.1.1. Rev. E 6.1.2. Rev. D 6.1.3. Rev. A – C 6.2. ATtiny5 6.2.1. Rev. E 6.2.2. Rev. D 6.2.3. Rev. A – C 6.3. ATtiny9 6.3.1. Rev. E 6.3.2. Rev. D 6.3.3. Rev. A – C 6.4. ATtiny10 6.4.1. Rev. E 6.4.2. Rev. C – D 6.4.3. Rev. A – B
