Datasheet LTC6433-15 (Analog Devices) - 5
DescriptionLow Frequency to 1.4GHz 50Ω Gain Block IF Amplifier
Pages / Page16 / 5 — ac elecTrical characTerisTics. TA = 25°C (Note 3), VCC = 5V, ZSOURCE = …
ac elecTrical characTerisTics. TA = 25°C (Note 3), VCC = 5V, ZSOURCE = ZLOAD = 50Ω, unless otherwise
ac elecTrical characTerisTics TA = 25°C (Note 3), VCC = 5V, ZSOURCE = ZLOAD = 50Ω, unless otherwise
LTC6433-15
ac elecTrical characTerisTics TA = 25°C (Note 3), VCC = 5V, ZSOURCE = ZLOAD = 50Ω, unless otherwise noted. Measurements are performed using Test Circuit A, measuring from 50Ω SMA to 50Ω SMA without de-embedding (Note 4). SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Frequency = 300MHz
S21 Power Gain De-Embedded to Package 15.8 dB OIP3 Output Third-Order Intercept Point POUT = 2dBm/Tone, Δf = 1MHz A-Grade 41.5 dBm B-Grade 40.0 dBm IM3 Third-Order Intermodulation POUT = 2dBm/Tone, Δf = 1MHz A-Grade –79.0 dBc B-Grade –76.0 dBc HD2 Second Harmonic Distortion POUT = 6dBm –51.9 dBc HD3 Third Harmonic Distortion POUT = 6dBm –72.0 dBc P1dB Output 1dB Compression Point 19.0 dBm NF Noise Figure De-Embedded to Package 3.61 dB
Frequency = 500MHz
S21 Power Gain De-Embedded to Package 15.5 dB OIP3 Output Third-Order Intercept Point POUT = 2dBm/Tone, Δf = 1MHz A-Grade 38.4 dBm B-Grade 37.0 dBm IM3 Third-Order Intermodulation POUT = 2dBm/Tone, Δf = 1MHz A-Grade –72.8 dBc B-Grade –70.0 dBc HD2 Second Harmonic Distortion POUT = 6dBm –51.0 dBc HD3 Third Harmonic Distortion POUT = 6dBm –70.0 dBc P1dB Output 1dB Compression Point 18.9 dBm NF Noise Figure De-Embedded to Package 3.93 dB
Frequency = 800MHz
S21 Power Gain De-Embedded to Package 15.0 dB OIP3 Output Third-Order Intercept Point POUT = 2dBm/Tone, Δf = 1MHz A-Grade 34.9 dBm B-Grade 33.5 dBm IM3 Third-Order Intermodulation POUT = 2dBm/Tone, Δf = 1MHz A-Grade –65.8 dBc B-Grade –63.0 dBc HD2 Second Harmonic Distortion POUT = 6dBm –47.0 dBc HD3 Third Harmonic Distortion POUT = 6dBm –59.5 dBc P1dB Output 1dB Compression Point 18.0 dBm NF Noise Figure De-Embedded to Package 4.40 dB
Frequency = 1000MHz
S21 Power Gain De-Embedded to Package 14.5 dB OIP3 Output Third-Order Intercept Point POUT = 2dBm/Tone, Δf = 1MHz A-Grade 33.3 dBm B-Grade 32.0 dBm IM3 Third-Order Intermodulation POUT = 2dBm/Tone, Δf = 1MHz A-Grade –62.6 dBc B-Grade –60.0 dBc HD2 Second Harmonic Distortion POUT = 6dBm –45.0 dBc HD3 Third Harmonic Distortion POUT = 6dBm –57.0 dBc P1dB Output 1dB Compression Point 17.3 dBm NF Noise Figure De-Embedded to Package 4.83 dB
Note 1:
Stresses beyond those listed under Absolute Maximum Ratings may
Note 3:
The LTC6433-15 is guaranteed functional over the case operating cause permanent damage to the device. Exposure to any Absolute Maximum temperature range of –40°C to 85°C. Rating condition for extended periods may affect device reliability and lifetime.
Note 4:
Small-signal parameters S and noise are de-embedded to the package
Note 2:
Guaranteed by design and characterization. This parameter is not tested. pins, while large-signal parameters are measured directly from the circuit. 643315f For more information www.linear.com/LTC6433-15 5 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information DC Electrical Characteristics AC Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Test Circuit A Operation Applications Information S Parameters Package Description Related Parts Features Applications Typical Application Description Absolute Maximum Ratings Order Information DC Electrical Characteristics Pin Configuration AC Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Test Circuit A Operation S Parameters Package Description Typical Application Related Parts
