LT1719 PIN FUNCTIONSLT1719S8LT1719S6VCC (Pin 1): Positive Supply Voltage for Input Stage. –IN (Pin 1): Inverting Input of Comparator. + IN (Pin 2): Noninverting Input of Comparator. V– (Pin 2): Negative Supply, Usually Grounded. –IN (Pin 3): Inverting Input of Comparator. + IN (Pin3): Noninverting Input of Comparator. VEE (Pin 4): Negative Supply Voltage for Input Stage and V+ (Pin 4): Positive Supply Voltage. Chip Substrate. OUT (Pin 5): Output of Comparator. GND (Pin 5): Ground. SHDN (Pin 6): Shutdown. Pull to ground to enable SHDN (Pin 6): Shutdown. Pull to ground to enable comparator. comparator. OUT (Pin 7): Output of Comparator. +VS (Pin 8): Positive Supply Voltage for Output Stage. 1719fa 7
