Datasheet LT6700, LT6700HV (Analog Devices) - 4
Description | Micropower, Low Voltage, Dual Comparator with 400mV Reference |
Pages / Page | 20 / 4 — ELECTRICAL CHARACTERISTICS. TA = 25°C, (LT6700-1/LT6700-2/LT6700-3) … |
File Format / Size | PDF / 461 Kb |
ELECTRICAL CHARACTERISTICS. TA = 25°C, (LT6700-1/LT6700-2/LT6700-3) unless otherwise specified. SYMBOL. PARAMETER. CONDITIONS
LT6700/LT6700HV
ELECTRICAL CHARACTERISTICS TA = 25°C, (LT6700-1/LT6700-2/LT6700-3) unless otherwise specified. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VTH(R) Rising Input Threshold Voltage (Note 6) RL = 100k, VO = 2V Swing VS = 1.4V 394 400 406 mV VS = 5V 395 400 405 mV VS = 12V 393 400 407 mV VS = 18V 392 400 408 mV VTH(F) Falling Input Threshold Voltage (Note 6) RL = 100k, VO = 2V Swing VS = 1.4V 386 393.5 401 mV VS = 5V 387 393.5 400 mV VS = 12V 385 393.5 402 mV VS = 18V 384 393.5 403 mV HYS HYS = VTH(R) – VTH(F) VS = 1.4V, 5V, 12V, 18V, RL = 100k, VO = 2V Swing 3.5 6.5 9.5 mV IB Input Bias Current VS = 1.4V, 18V, VIN = VS ±0.01 ±10 nA VS = 1.4V, VIN = 18V ±0.01 ±10 nA VS = 1.4V, 18V, VIN = 0.1V ±4 ±10 nA VOL Output Low Voltage 10mV Input Overdrive VS = 1.4V, IOUT = 0.5mA 55 200 mV VS = 1.6V, IOUT = 3mA 60 200 mV VS = 5V, IOUT = 5mA 70 200 mV IOFF Output Leakage Current VS = 1.4V, 18V, VOUT = VS, VIN = 40mV Overdrive 0.01 0.8 µA VS = 1.4V, VOUT = 18V, VIN = 40mV Overdrive 0.01 0.8 µA tPD(HL) High-to-Low Propagation Delay VS = 5V, 10mV Input Overdrive, RL = 10k, 18 µs VOL = 400mV tPD(LH) Low-to-High Propagation Delay VS = 5V, 10mV Input Overdrive, RL = 10k, 29 µs VOH = 0.9 • VS tr Output Rise Time VS = 5V, 10mV Input Overdrive, RL = 10k 2.2 µs VO = (0.1 to 0.9) • VS tf Output Fall Time VS = 5V, 10mV Input Overdrive, RL = 10k 0.22 µs VO = (0.1 to 0.9) • VS IS Supply Current No Load Current VS = 1.4V 5.7 10.0 µA VS = 5V 6.5 11.0 µA VS = 12V 6.9 12.5 µA VS = 18V 7.1 13.0 µA
The
denotes the specifications which apply over the temperature range of 0°C ≤ TA ≤ 70°C, (LT6700C-1/LT6700C-2/LT6700C-3) unless otherwise specified (Notes 4, 5). SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VTH(R) Rising Input Threshold Voltage (Note 6) RL = 100k, VO = 2V Swing VS = 1.4V l 391.0 409.0 mV VS = 5V l 392.5 407.5 mV VS = 12V l 390.0 410.0 mV VS = 18V l 389.0 411.0 mV VTH(F) Falling Input Threshold Voltage (Note 6) RL = 100k, VO = 2V Swing VS = 1.4V l 383.5 403.5 mV VS = 5V l 384.5 402.5 mV VS = 12V l 382.5 404.5 mV VS = 18V l 381.5 405.5 mV 6700123fh 4 For more information www.linear.com/LT6700 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Pin Functions Typical Performance Characteristics Applications Information Package Information Revision History Typical Applications Related Parts
