Datasheet LT6700, LT6700HV (Analog Devices) - 5
DescriptionMicropower, Low Voltage, Dual Comparator with 400mV Reference
Pages / Page20 / 5 — ELECTRICAL CHARACTERISTICS. The
File Format / SizePDF / 461 Kb
LT6700
LT6700-1
LT6700-2
LT6700-3
LT6700HV-1
LT6700HV-2
LT6700HV-3
LT6700/LT6700HV
l
denotes the specifications which apply over the temperature range of 0°C ≤ TA ≤ 70°C, (LT6700C-1/LT6700C-2/LT6700C-3) unless otherwise specified (Notes 4, 5). SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
HYS HYS = VTH(R) – VTH(F) VS = 1.4V, 5V, 12V, 18V, RL = 100k, VO = 2V Swing l 3 11 mV IB Input Bias Current VS = 1.4V, 18V, VIN = VS l ±15 nA VS = 1.4V, VIN = 18V l ±15 nA VS = 1.4V, 18V, VIN = 0.1V l ±15 nA VOL Output Low Voltage 10mV Input Overdrive VS = 1.4V, IOUT = 0.5mA l 250 mV VS = 1.6V, IOUT = 3mA l 250 mV VS = 5V, IOUT = 5mA l 250 mV IOFF Output Leakage Current VS = 1.4V, 18V, VOUT = VS, VIN = 40mV Overdrive l 1 µA VS = 1.4V, VOUT = 18V, VIN = 40mV Overdrive l 1 µA IS Supply Current No Load Current VS = 1.4V l 13.0 µA VS = 5V l 14.0 µA VS = 12V l 15.5 µA VS = 18V l 16.0 µA
The
l
denotes the specifications which apply over the temperature range of –40°C ≤ TA ≤ 85°C, (LT6700I-1/LT6700I-2/LT6700I-3) unless otherwise specified (Notes 4, 5). SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VTH(R) Rising Input Threshold Voltage (Note 6) RL = 100k, VO = 2V Swing VS = 1.4V l 390 410 mV VS = 5V l 392 408 mV VS = 12V l 389 411 mV VS = 18V l 388 412 mV VTH(F) Falling Input Threshold Voltage (Note 6) RL = 100k, VO = 2V Swing VS = 1.4V l 382.5 404.5 mV VS = 5V l 383.5 403.5 mV VS = 12V l 381.5 405.5 mV VS = 18V l 380.5 406.5 mV HYS HYS = VTH(R) – VTH(F) VS = 1.4V, 5V, 12V, 18V, RL = 100k, VO = 2V Swing l 2 11.5 mV IB Input Bias Current VS = 1.4V, 18V, VIN = VS l ±15 nA VS = 1.4V, VIN = 18V l ±15 nA VS = 1.4V, 18V, VIN = 0.1V l ±15 nA VOL Output Low Voltage 10mV Input Overdrive VS = 1.4V, IOUT = 0.1mA l 250 mV VS = 1.6V, IOUT = 3mA l 250 mV VS = 5V, IOUT = 5mA l 250 mV IOFF Output Leakage Current VS = 1.4V, 18V, VOUT = VS, VIN = 40mV Overdrive l 1 µA VS = 1.4V, VOUT = 18V, VIN = 40mV Overdrive l 1 µA IS Supply Current No Load Current VS = 1.4V l 14.0 µA VS = 5V l 15.0 µA VS = 12V l 16.5 µA VS = 18V l 17.0 µA 6700123fh For more information www.linear.com/LT6700 5 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Pin Functions Typical Performance Characteristics Applications Information Package Information Revision History Typical Applications Related Parts
