Datasheet LT6703-2, LT6703-3, LT6703HV-2, LT6703HV-3 (Analog Devices) - 3
Description | Micropower, Low Voltage Comparator with 400mV Reference |
Pages / Page | 14 / 3 — ORDER INFORMATION Lead Free Finish. TAPE AND REEL (MINI). TAPE AND REEL. … |
File Format / Size | PDF / 186 Kb |
ORDER INFORMATION Lead Free Finish. TAPE AND REEL (MINI). TAPE AND REEL. PART MARKING*. PACKAGE DESCRIPTION
LT6703-2/LT6703-3 LT6703HV-2/LT6703HV-3
ORDER INFORMATION Lead Free Finish TAPE AND REEL (MINI) TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION SPECIFIED TEMPERATURE RANGE
LT6703CDC-2#TRMPBF LT6703CDC-2#TRPBF LCWP 3-Lead (2mm × 2mm) Plastic DFN 0°C to 70°C LT6703IDC-2#TRMPBF LT6703IDC-2#TRPBF LCWP 3-Lead (2mm × 2mm) Plastic DFN – 40°C to 85°C LT6703HDC-2#TRMPBF LT6703HDC-2#TRPBF LCWP 3-Lead (2mm × 2mm) Plastic DFN – 40°C to 125°C LT6703CDC-3#TRMPBF LT6703CDC-3#TRPBF LCTW 3-Lead (2mm × 2mm) Plastic DFN 0°C to 70°C LT6703IDC-3#TRMPBF LT6703IDC-3#TRPBF LCTW 3-Lead (2mm × 2mm) Plastic DFN – 40°C to 85°C LT6703HDC-3#TRMPBF LT6703HDC-3#TRPBF LCTW 3-Lead (2mm × 2mm) Plastic DFN – 40°C to 125°C LT6703HVCS5-2#TRMPBF LT6703HVCS5-2#TRPBF LTDMN 5-Lead Plastic TSOT-23 0°C to 70°C LT6703HVIS5-2#TRMPBF LT6703HVIS5-2#TRPBF LTDMN 5-Lead Plastic TSOT-23 – 40°C to 85°C LT6703HVHS5-2#TRMPBF LT6703HVHS5-2#TRPBF LTDMN 5-Lead Plastic TSOT-23 – 40°C to 125°C LT6703HVCS5-3#TRMPBF LT6703HVCS5-3#TRPBF LTDMP 5-Lead Plastic TSOT-23 0°C to 70°C LT6703HVIS5-3#TRMPBF LT6703HVIS5-3#TRPBF LTDMP 5-Lead Plastic TSOT-23 – 40°C to 85°C LT6703HVHS5-3#TRMPBF LT6703HVHS5-3#TRPBF LTDMP 5-Lead Plastic TSOT-23 – 40°C to 125°C TRM = 500 pieces. *Temperature grades are identifi ed by a label on the shipping container. Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. Consult LTC Marketing for information on lead based fi nish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifi cations, go to: http://www.linear.com/tapeandreel/
ELECTRICAL CHARACTERISTICS TA = 25°C (LT6703-2/LT6703-3) unless otherwise specifi ed. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VTH(R) Rising Input Threshold Voltage (Note 6) RL = 100k, VO = 2V Swing, VS = 5V 395 400 405 mV VTH(F) Falling Input Threshold Voltage (Note 6) RL = 100k, VO = 2V Swing, VS = 5V 387 393.5 400 mV HYS HYS = VTH(R) – VTH(F) VS = 5V, RL = 100k, VO = 2V Swing 3.5 6.5 9.5 mV IB Input Bias Current VS = 1.4V, 18V, VIN = VS ±0.01 ±10 nA VS = 1.4V, VIN = 18V ±0.01 ±10 nA VS = 1.4V, 18V, VIN = 0.1V ±4 ±10 nA VOL Output Low Voltage 10mV Input Overdrive, VS = 5V, IOUT = 5mA 70 200 mV IOFF Output Leakage Current VS = 1.4V, 18V, VOUT = VS, VIN = 40mV Overdrive 0.01 0.8 μA VS = 1.4V, VOUT = 18V, VIN = 40mV Overdrive 0.01 0.8 μA tPD(HL) High-to-Low Propagation Delay VS = 5V, 10mV Input Overdrive, RL = 10k, 18 μs VOL = 400mV tPD(LH) Low-to-High Propagation Delay VS = 5V, 10mV Input Overdrive, RL = 10k, 29 μs VOH = 0.9 • VS tr Output Rise Time VS = 5V, 10mV Input Overdrive, RL = 10k 2.2 μs VO = (0.1 to 0.9) • VS tf Output Fall Time VS = 5V, 10mV Input Overdrive, RL = 10k 0.22 μs VO = (0.1 to 0.9) • VS IS Supply Current No Load Current, VS = 5V 6.5 11 μA 670323fd 3
