Datasheet LTC6752, LTC6752-1, LTC6752-2, LTC6752-3, LTC6752-4 (Analog Devices) - 3
Description280MHz, 2.9ns Comparator Family with Rail-to-Rail Inputs and CMOS Outputs
Pages / Page30 / 3 — orDer inForMaTion http://www.linear.com/product/LTC6752#orderinfo. Lead …
File Format / SizePDF / 711 Kb
orDer inForMaTion http://www.linear.com/product/LTC6752#orderinfo. Lead Free Finish TAPE AND REEL (MINI). TAPE AND REEL
orDer inForMaTion http://www.linear.com/product/LTC6752#orderinfo Lead Free Finish TAPE AND REEL (MINI) TAPE AND REEL
LTC6752/LTC6752-1/ LTC6752-2/LTC6752-3/ LTC6752-4
orDer inForMaTion http://www.linear.com/product/LTC6752#orderinfo Lead Free Finish TAPE AND REEL (MINI) TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION SPECIFIED TEMPERATURE RANGE
LTC6752IS5#TRMPBF LTC6752IS5#TRPBF LTGKT 5-Lead Plastic TSOT-23 –40°C to 85°C LTC6752HS5#TRMPBF LTC6752HS5#TRPBF LTGKT 5-Lead Plastic TSOT-23 –40°C to 125°C LTC6752MPS5#TRMPBF LTC6752MPS5#TRPBF LTGKT 5-Lead Plastic TSOT-23 –55°C to 125°C LTC6752ISC6-1#TRMPBF LTC6752ISC6-1#TRPBF LGQK 6-Lead Plastic SC-70 –40°C to 85°C LTC6752HSC6-1#TRMPBF LTC6752HSC6-1#TRPBF LGQK 6-Lead Plastic SC-70 –40°C to 125°C LTC6752ISC6-4#TRMPBF LTC6752ISC6-4#TRPBF LGQM 6-Lead Plastic SC-70 –40°C to 85°C LTC6752HSC6-4#TRMPBF LTC6752HSC6-4#TRPBF LGQM 6-Lead Plastic SC-70 –40°C to 125°C TRM = 500 pieces. *Temperature grades are identified by a label on the shipping container.
LEAD FREE FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION SPECIFIED TEMPERATURE RANGE
LTC6752IMS8-2#PBF LTC6752IMS8-2#TRPBF LTGKW 8-Lead Plastic MSOP –40°C to 85°C LTC6752HMS8-2#PBF LTC6752HMS8-2#TRPBF LTGKW 8-Lead Plastic MSOP –40°C to 125°C LTC6752IUD-3#PBF LTC6752IUD-3#TRPBF LGKV 12-Lead Plastic QFN (3mm × 3mm) –40°C to 85°C LTC6752HUD-3#PBF LTC6752HUD-3#TRPBF LGKV 12-Lead Plastic QFN (3mm × 3mm) –40°C to 125°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. Consult LTC Marketing for information on nonstandard lead based finish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/ Some packages are available in 500 unit reels through designated sales channels with #TRMPBF suffix.
elecTrical characTerisTics (VCC = 2.5V, VDD = 2.5V, VEE = 0). The
denotes the specifications which apply over the specified temperature range, otherwise specifications are at TA = 25°C. LE/HYST, SHDN pins floating, CL = 5pF, VOVERDRIVE = 50mV, –IN = VCM = 300mV, +IN = –IN + VOVERDRIVE, 150mV step size unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VCC - VEE Supply Voltage (Note 5) LTC6752/LTC6752-1 (Total Supply) l 2.45 3.5 V LTC6752-2/LTC6752-3/LTC6752-4 (Input Stage) l 2.45 5.25 V VDD - VEE Output Stage Supply Voltage (Note 5) LTC6752-2/LTC6752-3/LTC6752-4 l 1.71 3.5 V VCMR Input Voltage Range (Note 7) l VEE – 0.2 VCC + 0.1 V VOS Input Offset Voltage (Note 6) –5.5 ±1.2 5.5 mV l –8.5 8.5 mV TCVOS Input Offset Voltage Drift l 18 µV/°C VHYST Input Hysteresis Voltage (Note 6) LE/HYST Pin Floating 5 mV CIN Input Capacitance 1.1 pF RDM Differential Mode Resistance 57 kΩ RCM Common Mode Resistance 6.4 MΩ IB Input Bias Current VCM = VEE + 0.3V –3.8 –1.35 µA l –4 µA VCM = VCC – 0.3V 0.3 1.25 µA l 2.1 µA IOS Input Offset Current l –0.75 ±0.1 0.75 µA CMRR_ Common Mode Input Range, Low VCM VCM = VEE – 0.2V to VCC – 1.5V 51 69 dB LVCM Region l 46 dB CMRR_FR Common Mode Rejection Ratio (Measured at VCM = VEE – 0.2V to VCC + 0.1V 50 65 dB Extreme Ends of VCMR) l 45.5 dB 6752fc For more information www.linear.com/LTC6752 3 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics DC Typical Performance Characteristics AC Pin Functions Block Diagram Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
