Datasheet LTC6752, LTC6752-1, LTC6752-2, LTC6752-3, LTC6752-4 (Analog Devices) - 10
Description | 280MHz, 2.9ns Comparator Family with Rail-to-Rail Inputs and CMOS Outputs |
Pages / Page | 30 / 10 — Typical. perForMance characTerisTics Dc VCC = VDD = 2.5V, CLOAD = 5pF, |
File Format / Size | PDF / 711 Kb |
LTC6752/LTC6752-1/ LTC6752-2/LTC6752-3/ LTC6752-4
Typical perForMance characTerisTics Dc VCC = VDD = 2.5V, CLOAD = 5pF, VOVERDRIVE = 50mV, VCM = 300mV,TA = 25°C unless otherwise noted. VCC ≠ VDD conditions applicable only to the LTC6752-2/LTC6752-3/ LTC6752-4. Input Offset Voltage and Input Offset Voltage and Input Offset Voltage and Hysteresis vs Temperature Hysteresis vs VCC Voltage Hysteresis vs VDD Voltage
8 6 7 HYSTERESIS 6 5 6 HYSTERESIS 5 4 4 4 2 3 3 , HYSTERESIS (mV) , HYSTERESIS (mV) 0 2 2 OFFSET/HYSTERESIS (mV) OFFSET OFFSET OFFSET –2 1 OFFSET V 1 HYST VOS –4 0 0 –55 –35 –15 5 25 45 65 85 105 125 2.45 3.15 3.85 4.55 5.25 1.6 2.1 2.6 3.1 3.6 TEMPERATURE (°C) VCC VOLTAGE (V) VDD VOLTAGE (V) 6752 G01 6752 G02 6752 G03
Input Offset Voltage and Input Bias Current vs Common Hysteresis vs Input Common Mode Input Bias Current vs Temperature Mode Voltage
7 0.8 0.5 6 0.6 HYSTERESIS 5 0.4 0 VIN = VOS V 4 0.2 CM = 2.2V 0 3 –0.5 –0.2 2 OFFSET –0.4 , HYSTERESIS (mV) 1 –1.0 –0.6 0 –0.8 OFFSET –1 INPUT BIAS CURRENT (µA) V INPUT BIAS CURRENT (µA) CM = 300mV –1.5 –1.0 –2 –1.2 –3 –1.4 –2.0 –0.2 0.2 0.6 1.0 1.4 1.8 2.2 2.6 –55 –35 –15 5 25 45 65 85 105 125 –0.2 0.2 0.6 1.0 1.4 1.8 2.2 2.6 INPUT COMMON MODE VOLTAGE (V) TEMPERATURE (°C) INPUT COMMON MODE VOLTAGE (V) 6752 G04 6752 G05 6752 G06
Input Bias Current vs Differential Input Hysteresis vs LE/HYST Pin Input Voltage Voltage LE/HYST Pin I-V Characteristics
1.0 50 200 0.5 –IN 150 0 40 VCC = 5V –0.5 100 30 –1.0 VCC = 5V VCC = 2.5V VDD = 2.5V 50 –1.5 VCM = 2.5V 20 BIAS CURRENT (µA) –2.0 +IN HYSTERESIS (mV) 0 /HYST PIN CURRENT (µA) –2.5 10 LE –50 –3.0 –3.5 0 –100 –5.4 –4.2 –3.0 –1.8 –0.6 0.6 1.8 3.0 4.2 5.4 0.75 1.00 1.25 1.50 1.75 –0.3 0.5 1.3 2.1 2.9 3.7 4.5 5.3 INPUT DIFFERENTIAL VOLTAGE (V) LE/HYST VOLTAGE (V) LE/HYST PIN VOLTAGE (V) 6752 G07 6752 G08 6752 G09 6752fc 10 For more information www.linear.com/LTC6752 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics DC Typical Performance Characteristics AC Pin Functions Block Diagram Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
