Datasheet MCP6L01, MCP6L01R, MCP6L01U, MCP6L012, MCP6L014 (Microchip) - 6
ManufacturerMicrochip
DescriptionThe MCP6L01 is a single general purpose op amp offering rail-to-rail input and output over the 1.8 to 6V operating range
Pages / Page38 / 6 — MCP6L01/1R/1U/2/4. Note:. 1.E-0. 10 2. 1.E-03. ) 5. 1.E-04. 100µ. 1.E. s …
MCP6L01/1R/1U/2/4. Note:. 1.E-0. 10 2. 1.E-03. ) 5. 1.E-04. 100µ. 1.E. s (V. itude. -05. 10µ. 1.E-06. ag lt. Mag. -07. 100n. o 3. 1.E-08. 10n. t V u 2. rrent. -09. t C
MCP6L01/1R/1U/2/4 Note: 1.E-0 10 2 1.E-03 ) 5 1.E-04 100µ 1.E s (V itude -05 10µ 1.E-06 ag lt Mag -07 100n o 3 1.E-08 10n t V u 2 rrent -09 t C
Unless otherwise indicated, TA = +25°C, VDD = +5.0V, VSS = GND, VCM = VSS, VOUT = VDD/2, VL = VDD/2, RL = 10 kto VL and CL = 60 pF.
1.E-0 10 2 m 6 )
VIN G = +2 V/V
1.E-03 (A 1m ) 5 1.E-04 100µ
VOUT
1.E s (V itude -05 10µ e n 4 1.E-06 ag lt 1.E Mag -07 100n o 3 1.E-08 10n t V u 2 1.E rrent tp u -09 1n
+125°C +85°C
1.E t C -10 100p
+25°C
1 t, Ou 1.E-11 10p
-40°C
u Inpu p 0 1.E-12 1p In -1.0 -0.9 -0.8 -0.7 -0.6 -0.5 -0.4 -0.3 -0.2 -0.1 0.0 -1 0.E+00 1.E-05 2.E-05 3.E-05 4.E-05 5.E-05 6.E-05 7.E-05 8.E-05 9.E-05 1.E-04 Input Voltage (V) Time (10 µs/div) FIGURE 2-7:
Measured Input Current vs.
FIGURE 2-10:
The MCP6L01/1R/1U/2/4 Input Voltage (below VSS). Show No Phase Reversal.
120 0 180 160 ) 100 -30 t B ) (°) 140 A (d 80 -60 rren 120 in
Phase
ase u 60 h 100 Ga -90 t C ifier (µ p p P n pl o 80 40 o -120 m -L
Gain
Loo 60 iesce r a 20
+125°
en -150 en- u pe 40 Q
C
Op 0 -180 Op 20
+85°C +25°C
-20 -210 0
40°C
1. 0E.- 1 1.E1+ 1.E+ 10 1.E+ 100 1.E+ 1k 1.E+ 10k 1.E 10 + 0k 1.E+ 1M 1.E 10 + M 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 01 00 01 02 Freq 03 uen 04 cy (Hz) 05 06 07 Power Supply Voltage (V) FIGURE 2-8:
Open-Loop Gain, Phase vs.
FIGURE 2-11:
Quiescent Current vs. Frequency. Power Supply Voltage.
1,000 30 ) 25 A 20 (m 15 ent 10 rr 5 u
-40°C
100 0
+25°C
it C
+85°C
(nV/Hz) -5
+125°C
ircu -10 t C -15 -20 hor Input Noise Voltage Density S -25 10 -30 1.E-01 0.1 1.E+0 1 1.E+0 10 1.E+0 100 1.E+0 1k 1.E+0 10k 1.E+0 100k 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 0 1 2 3 Frequency (Hz) 4 5 Power Supply Voltage (V) FIGURE 2-9:
FIGURE 2-12:
Output Short Circuit Current vs. Frequency. vs. Power Supply Voltage. DS22140B-page 6  2009-2011 Microchip Technology Inc. Document Outline 1.0 Electrical Characteristics 1.1 Absolute Maximum Ratings † 1.2 Specifications TABLE 1-1: DC Electrical Specifications TABLE 1-2: AC Electrical Specifications TABLE 1-3: Temperature Specifications 1.3 Test Circuit FIGURE 1-1: AC and DC Test Circuit for Most Specifications. 2.0 Typical Performance Curves FIGURE 2-1: Input Offset Voltage vs. Common Mode Input Voltage at VDD = 1.8V. FIGURE 2-2: Input Offset Voltage vs. Common Mode Input Voltage at VDD = 5.5V. FIGURE 2-3: Input Offset Voltage vs. Output Voltage. FIGURE 2-4: Input Common Mode Range Voltage vs. Ambient Temperature. FIGURE 2-5: CMRR, PSRR vs. Ambient Temperature. FIGURE 2-6: CMRR, PSRR vs. Frequency. FIGURE 2-7: Measured Input Current vs. Input Voltage (below VSS). FIGURE 2-8: Open-Loop Gain, Phase vs. Frequency. FIGURE 2-9: Input Noise Voltage Density vs. Frequency. FIGURE 2-10: The MCP6L01/1R/1U/2/4 Show No Phase Reversal. FIGURE 2-11: Quiescent Current vs. Power Supply Voltage. FIGURE 2-12: Output Short Circuit Current vs. Power Supply Voltage. FIGURE 2-13: Ratio of Output Voltage Headroom to Output Current vs. Output Current. FIGURE 2-14: Small Signal, Noninverting Pulse Response. FIGURE 2-15: Large Signal, Noninverting Pulse Response. FIGURE 2-16: Slew Rate vs. Ambient Temperature. FIGURE 2-17: Output Voltage Swing vs. Frequency. 3.0 Pin Descriptions TABLE 3-1: Pin Function Table 3.1 Analog Outputs 3.2 Analog Inputs 3.3 Power Supply Pins 4.0 Application Information 4.1 Rail-to-Rail Inputs FIGURE 4-1: Protecting the Analog Inputs. 4.2 Rail-to-Rail Output 4.3 Capacitive Loads FIGURE 4-2: Output Resistor, RISO stabilizes large capacitive loads. 4.4 Supply Bypass 4.5 Unused Op Amps FIGURE 4-3: Unused Op Amps. 4.6 PCB Surface Leakage FIGURE 4-4: Example Guard Ring Layout. 4.7 Application Circuit FIGURE 4-5: Bessel Filter. 5.0 Design Aids 5.1 SPICE Macro Model 5.2 FilterLab® Software 5.3 Microchip Advanced Part Selector (MAPS) 5.4 Analog Demonstration and Evaluation Boards 5.5 Application Notes 6.0 Packaging Information 6.1 Package Marking Information Appendix A: Revision History Product ID System Trademarks Worldwide Sales
