Datasheet MCP6H01, MCP6H02, MCP6H04 (Microchip) - 3
ManufacturerMicrochip
DescriptionThe MCP6H01 operational amplifier (op amp) has a wide supply voltage range of 3.5V to 16V and rail-to-rail output operation
Pages / Page46 / 3 — MCP6H01/2/4. 1.0. ELECTRICAL CHARACTERISTICS. 1.1. Absolute Maximum …
MCP6H01/2/4. 1.0. ELECTRICAL CHARACTERISTICS. 1.1. Absolute Maximum Ratings †. † Notice:. 4.1.2 “Input Voltage Limits”
MCP6H01/2/4 1.0 ELECTRICAL CHARACTERISTICS 1.1 Absolute Maximum Ratings † † Notice: 4.1.2 “Input Voltage Limits”
link to page 5 link to page 17
V
† Notice:
DD – VSS..17V Stresses above those listed under “Absolute Current at Input Pins..±2 mA Maximum Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of Analog Inputs (VIN+, VIN-)††...VSS – 1.0V to VDD + 1.0V the device at those or any other conditions above those All Other Inputs and Outputs ..VSS – 0.3V to VDD + 0.3V indicated in the operational listings of this specification is not Difference Input Voltage..VDD – VSS implied. Exposure to maximum rating conditions for extended Output Short-Circuit Current...continuous periods may affect device reliability. Current at Output and Supply Pins ..±65 mA
See
4.1.2 “Input Voltage Limits”.
Storage Temperature...-65°C to +150°C Maximum Junction Temperature (TJ)...+150°C ESD protection on all pins (HBM; MM) 2 kV; 200V
DC ELECTRICAL SPECIFICATIONS Electrical Characteristics
: Unless otherwise indicated, VDD = +3.5V to +16V, VSS = GND, TA = +25°C, V  CM = VDD/2 – 1.4V, VOUT VDD/2, VL = VDD/2 and RL = 10 kto VL. (Refer to Figure 1-1).
Parameters Sym Min Typ Max Units Conditions Input Offset
Input Offset Voltage VOS -3.5 ±0.7 +3.5 mV Input Offset Drift with Temperature VOS/TA — ±2.5 — µV/°C TA = -40°C to +125°C Power Supply Rejection Ratio PSRR 87 102 — dB
Input Bias Current and Impedance
Input Bias Current IB — 10 — pA IB — 600 — pA TA = +85°C IB — 10 25 nA TA = +125°C Input Offset Current IOS — ±1 — pA Common Mode Input Impedance ZCM — 1013||6 — ||pF Differential Input Impedance ZDIFF — 1013||6 — ||pF
Common Mode
Common Mode Input Voltage Range V   CMR VSS 0.3 — VDD 2.3 V Common Mode Rejection Ratio CMRR 78 93 — dB VCM = -0.3V to 1.2V, VDD = 3.5V 82 98 — dB VCM = -0.3V to 2.7V, VDD = 5V 84 100 — dB VCM = -0.3V to 12.7V, VDD = 15V
Open-Loop Gain
DC Open-Loop Gain (Large Signal) AOL 95 115 — dB 0.2V < VOUT <(VDD – 0.2V)  2010-2011 Microchip Technology Inc. DS22243D-page 3 Document Outline 1.0 Electrical Characteristics 1.1 Absolute Maximum Ratings † 1.2 Test Circuits FIGURE 1-1: AC and DC Test Circuit for Most Specifications. 2.0 Typical Performance Curves FIGURE 2-1: Input Offset Voltage. FIGURE 2-2: Input Offset Voltage Drift. FIGURE 2-3: Input Offset Voltage vs. Common Mode Input Voltage. FIGURE 2-4: Input Offset Voltage vs. Common Mode Input Voltage. FIGURE 2-5: Input Offset Voltage vs. Common Mode Input Voltage. FIGURE 2-6: Input Offset Voltage vs. Output Voltage. FIGURE 2-7: Input Offset Voltage vs. Power Supply Voltage. FIGURE 2-8: Input Noise Voltage Density vs. Frequency. FIGURE 2-9: Input Noise Voltage Density vs. Common Mode Input Voltage. FIGURE 2-10: CMRR, PSRR vs. Frequency. FIGURE 2-11: CMRR, PSRR vs. Ambient Temperature. FIGURE 2-12: Input Bias, Offset Currents vs. Ambient Temperature. FIGURE 2-13: Input Bias Current vs. Common Mode Input Voltage. FIGURE 2-14: Quiescent Current vs. Ambient Temperature. FIGURE 2-15: Quiescent Current vs. Power Supply Voltage. FIGURE 2-16: Open-Loop Gain, Phase vs. Frequency. FIGURE 2-17: DC Open-Loop Gain vs. Power Supply Voltage. FIGURE 2-18: DC Open-Loop Gain vs. Output Voltage Headroom. FIGURE 2-19: Channel-to-Channel Separation vs. Frequency (MCP6H02 only). FIGURE 2-20: Gain Bandwidth Product, Phase Margin vs. Ambient Temperature. FIGURE 2-21: Gain Bandwidth Product, Phase Margin vs. Ambient Temperature. FIGURE 2-22: Output Short Circuit Current vs. Power Supply Voltage. FIGURE 2-23: Output Voltage Swing vs. Frequency. FIGURE 2-24: Output Voltage Headroom vs. Output Current. FIGURE 2-25: Output Voltage Headroom vs. Output Current. FIGURE 2-26: Output Voltage Headroom vs. Output Current. FIGURE 2-27: Output Voltage Headroom vs. Ambient Temperature. FIGURE 2-28: Output Voltage Headroom vs. Ambient Temperature. FIGURE 2-29: Output Voltage Headroom vs. Ambient Temperature. FIGURE 2-30: Slew Rate vs. Ambient Temperature. FIGURE 2-31: Slew Rate vs. Ambient Temperature. FIGURE 2-32: Small Signal Non-Inverting Pulse Response. FIGURE 2-33: Small Signal Inverting Pulse Response. FIGURE 2-34: Large Signal Non-Inverting Pulse Response. FIGURE 2-35: Large Signal Inverting Pulse Response. FIGURE 2-36: The MCP6H01/2/4 Shows No Phase Reversal. FIGURE 2-37: Closed Loop Output Impedance vs. Frequency. FIGURE 2-38: Measured Input Current vs. Input Voltage (below VSS). 3.0 Pin Descriptions TABLE 3-1: Pin Function Table 3.1 Analog Outputs 3.2 Analog Inputs 3.3 Power Supply Pins 3.4 Exposed Thermal Pad (EP) 4.0 Application Information 4.1 Inputs FIGURE 4-1: Simplified Analog Input ESD Structures. FIGURE 4-2: Protecting the Analog Inputs. FIGURE 4-3: Protecting the Analog Inputs. 4.2 Rail-to-Rail Output 4.3 Capacitive Loads FIGURE 4-4: Output Resistor, RISO Stabilizes Large Capacitive Loads. FIGURE 4-5: Recommended RISO Values for Capacitive Loads. 4.4 Supply Bypass 4.5 Unused Op Amps FIGURE 4-6: Unused Op Amps. 4.6 PCB Surface Leakage FIGURE 4-7: Example Guard Ring Layout for Inverting Gain. 4.7 Application Circuits FIGURE 4-8: High Side Current Sensing Using Difference Amplifier. FIGURE 4-9: Two Op Amp Instrumentation Amplifier. FIGURE 4-10: Photodetector Amplifier. 5.0 Design Aids 5.1 SPICE Macro Model 5.2 FilterLab Software 5.3 MAPS (Microchip Advanced Part Selector) 5.4 Analog Demonstration and Evaluation Boards 5.5 Application Notes 6.0 Packaging Information 6.1 Package Marking Information Corporate Office Atlanta Boston Chicago Cleveland Fax: 216-447-0643 Dallas Detroit Indianapolis Toronto Fax: 852-2401-3431 Australia - Sydney China - Beijing China - Shanghai India - Bangalore Korea - Daegu Korea - Seoul Singapore Taiwan - Taipei Fax: 43-7242-2244-393 Denmark - Copenhagen France - Paris Germany - Munich Italy - Milan Spain - Madrid UK - Wokingham Worldwide Sales and Service
