Datasheet MCP6L71, MCP6L71R, MCP6L72, MCP6L74 (Microchip) - 9 Manufacturer Microchip Description The MCP6L71 operational amplifier has 2MHz Gain Bandwidth Product and a low 150uA per amplifier quiescent current Pages / Page 32 / 9 — MCP6L71/1R/2/4. Note:. 1.8. 1.6. DD = 5.5V. OL – VSS. ) 1.4. OUT. Falling … File Format / Size PDF / 464 Kb Document Language English
MCP6L71/1R/2/4. Note:. 1.8. 1.6. DD = 5.5V. OL – VSS. ) 1.4. OUT. Falling Edge. /µ 1.2. t (m. (V 1.0. t He. rre. 0.8. = 2.0V. w 0.6. t Cu. VDD – VOH. f O
Model Line for this Datasheet Text Version of Document MCP6L71/1R/2/4 Note: Unless otherwise indicated, T ≈ A = +25°C, VDD = 5.0V, VSS = GND, VCM = VDD/2, VOUT VDD/2, VL = VDD/2, RL = 10 kΩ to VL and CL = 60 pF.50 1.8 to ) 45 1.6 A V V DD = 5.5V om 40 OL – VSS -I ) 1.4 ro /m OUT s Falling Edge d V 35 a /µ 1.2 30 t (m (V 1.0 t He n 25 te u a rre 0.8 tp 20 R V = 2.0V DD u w 0.6 t Cu 15 VDD – VOH e f O u Sl Rising Edge 10 I 0.4 o tp OUT o u ti 5 O 0.2 Ra 0 0.0 0.1 1 10 -50 -25 0 25 50 75 100 125 Output Current Magnitude (mA) Ambient Temperature (°C) FIGURE 2-13: Ratio of Output VoltageFIGURE 2-16: Slew Rate vs. Ambient Headroom vs. Output Current Magnitude. Temperature.5.0 10 e 4.5 G = +1 V/V g V = 5.0V lta V ) 4.0 DD o DD = 5.5V V ) ( 3.5 t V P e u P- g V V = 2.0V 3.0 tp ( DD lta u g 1 o 2.5 O in t V m u 2.0 u Sw tp m 1.5 xi Ou a 1.0 M 0.5 0.1 0.0 03 1k 1004k 10 05 0k 1 06 M 07 10M + + E+ E+ Time (5 µs/div) 1.E 1.E+ Freque 1.ncy (Hz) 1.E 1. FIGURE 2-14: Large Signal Non-invertingFIGURE 2-17: Maximum Output Voltage Pulse Response. Swing vs. Frequency.G = +1 V/V ) iv /d V m 0 1 ( e g a lt t Vo u tp u O Time (2 µs/div) FIGURE 2-15: Small Signal Non-inverting Pulse Response. © 2009 Microchip Technology Inc. DS22145A-page 9 Document Outline 1.0 Electrical Characteristics 1.1 Absolute Maximum Ratings † 1.2 Specifications TABLE 1-1: DC Electrical Specifications (Continued) TABLE 1-2: AC Electrical Specifications TABLE 1-3: Temperature Specifications 1.3 Test Circuits FIGURE 1-1: AC and DC Test Circuit for Most Specifications. 2.0 Typical Performance Curves FIGURE 2-1: Input Offset Voltage vs. Common Mode Input Voltage at VDD = 2.0V. FIGURE 2-2: Input Offset Voltage vs. Common Mode Input Voltage at VDD = 5.5V. FIGURE 2-3: Input Offset Voltage vs. Output Voltage. FIGURE 2-4: Input Common Mode Range Voltage vs. Ambient Temperature. FIGURE 2-5: CMRR, PSRR vs. Temperature. FIGURE 2-6: CMRR, PSRR vs. Frequency. FIGURE 2-7: Input Current vs. Input Voltage. FIGURE 2-8: Open-Loop Gain, Phase vs. Frequency. FIGURE 2-9: Input Noise Voltage Density vs. Frequency. FIGURE 2-10: The MCP6L71/1R/2/4 Show No Phase Reversal. FIGURE 2-11: Quiescent Current vs. Supply Voltage. FIGURE 2-12: Output Short Circuit Current vs. Supply Voltage. FIGURE 2-13: Ratio of Output Voltage Headroom vs. Output Current Magnitude. FIGURE 2-14: Large Signal Non-inverting Pulse Response. FIGURE 2-15: Small Signal Non-inverting Pulse Response. FIGURE 2-16: Slew Rate vs. Ambient Temperature. FIGURE 2-17: Maximum Output Voltage Swing vs. Frequency. 3.0 Pin Descriptions TABLE 3-1: Pin Function Table for Single Op Amps TABLE 3-2: Pin Function Table for Dual and Quad Op Amps 3.1 Analog Outputs 3.2 Analog Inputs 3.3 Power Supply Pins 4.0 Application Information 4.1 Rail-to-Rail Inputs FIGURE 4-1: Protecting the Analog Inputs. 4.2 Rail-to-Rail Output 4.3 Capacitive Loads FIGURE 4-2: Output Resistor, RISO Stabilizes Large Capacitive Loads. 4.4 Supply Bypass 4.5 Unused Amplifiers FIGURE 4-3: Unused Op Amps. 4.6 PCB Surface Leakage FIGURE 4-4: Example Guard Ring Layout. 4.7 Application Circuits FIGURE 4-5: Inverting Integrator. 5.0 Design Tools 5.1 FilterLab® Software 5.2 MAPS (Microchip Advanced Part Selector) 5.3 Analog Demonstration and Evaluation Boards 5.4 Application Notes 6.0 Packaging Information 6.1 Package Marking Information
