Datasheet ADA4895-1, ADA4895-2 (Analog Devices) - 24
DescriptionLow Power, 1 nV/√Hz, G ≥ 10 Stable, Rail-to-Rail Output Amplifier
Pages / Page24 / 24 — ADA4895-1/ADA4895-2. Data Sheet. 3.00 2.90 2.80. 3.00. 1.70. 2.80. 1.60. …
RevisionB
File Format / SizePDF / 599 Kb
ADA4895-1/ADA4895-2. Data Sheet. 3.00 2.90 2.80. 3.00. 1.70. 2.80. 1.60. 2.60. 1.50. PIN 1. INDICATOR. 0.95 BSC. 1.90. BSC. 1.30 1.15 0.90. 1.45 MAX
ADA4895-1/ADA4895-2 Data Sheet 3.00 2.90 2.80 3.00 1.70 2.80 1.60 2.60 1.50 PIN 1 INDICATOR 0.95 BSC 1.90 BSC 1.30 1.15 0.90 1.45 MAX
ADA4895-1/ADA4895-2 Data Sheet 3.00 2.90 2.80 6 5 4 3.00 1.70 2.80 1.60 2.60 1.50 1 2 3 PIN 1 INDICATOR 0.95 BSC 1.90 BSC 1.30 1.15 0.90 1.45 MAX 0.20 MAX 0.95 MIN 0.08 MIN 0.55 0.15 MAX 10° 0.45 SEATING 0.05 MIN 0.60 0.50 MAX PLANE BSC 0.35 0.30 MIN -A 8 0 0 -2 6 COMPLIANT TO JEDEC STANDARDS MO-178-AB -1 2 1
Figure 59. 6-Lead Small Outline Transistor Package [SOT-23] (RJ-6) Dimensions shown in millimeters
ORDERING GUIDE Ordering Model1 Temperature Range Package Description Package Option Quantity Branding
ADA4895-1ARZ −40°C to +125°C 8-Lead SOIC_N R-8 98 ADA4895-1ARZ-R7 −40°C to +125°C 8-Lead SOIC_N R-8 1,000 ADA4895-1ARZ-RL −40°C to +125°C 8-Lead SOIC_N R-8 2,500 ADA4895-1ARJZ-R2 −40°C to +125°C 6-Lead SOT-23 RJ-6 250 H3D ADA4895-1ARJZ-R7 −40°C to +125°C 6-Lead SOT-23 RJ-6 3,000 H3D ADA4895-1AR-EBZ Evaluation Board for the 8-Lead SOIC_N ADA4895-1ARJ-EBZ Evaluation Board for the 6-Lead SOT-23 ADA4895-2ARMZ −40°C to +125°C 10-Lead Mini Small Outline Package [MSOP] RM-10 50 H35 ADA4895-2ARMZ-R7 −40°C to +125°C 10-Lead Mini Small Outline Package [MSOP] RM-10 1,000 H35 ADA4895-2ARMZ-RL −40°C to +125°C 10-Lead Mini Small Outline Package [MSOP] RM-10 3,000 H35 ADA4895-2ARM-EBZ Evaluation Board 1 Z = RoHS Compliant Part.
©2012–2015 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. D10186-0-4/15(B)
Rev. B | Page 24 of 24 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAMS COMPANION PRODUCTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±5 V (OR +10 V) SUPPLY ±2.5 V (OR +5 V) SUPPLY ±1.5 V (OR +3 V) SUPPLY ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE MAXIMUM POWER DISSIPATION ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION AMPLIFIER DESCRIPTION INPUT PROTECTION DISABLE OPERATION DC ERRORS BIAS CURRENT CANCELLATION NOISE CONSIDERATIONS APPLICATIONS INFORMATION USING THE ADA4895-1/ADA4895-2 AT A GAIN < +10 HIGH GAIN BANDWIDTH APPLICATION FEEDBACK CAPACITOR APPLICATION WIDEBAND PHOTOMULTIPLIER PREAMPLIFIER LAYOUT CONSIDERATIONS Ground Plane Power Supply Bypassing OUTLINE DIMENSIONS ORDERING GUIDE
