Datasheet ADA4001-2 (Analog Devices)
Description | Low Noise, Low Input Bias Current, Rail-to-Rail Output, JFET Dual Op Amp |
Pages / Page | 13 / 1 — Low Noise, Low Input Bias Current, Rail-to-Rail. Output, JFET Dual … |
Revision | C |
File Format / Size | PDF / 372 Kb |
Low Noise, Low Input Bias Current, Rail-to-Rail. Output, JFET Dual Operational Amplifier. Data Sheet. ADA4001-2. FEATURES
Low Noise, Low Input Bias Current, Rail-to-Rail Output, JFET Dual Operational Amplifier Data Sheet ADA4001-2 FEATURES PIN CONFIGURATION Low TCVOS: ±5 µV/°C typical OUT A 1 8 V+ Low input bias current: 20 pA typical at VSY = ±15 V –IN A ADA4001-2 2 7 OUT B TOP VIEW Low noise +IN A 3 6 –IN B (Not to Scale)
002
7.7 nV/√Hz typical at f = 1 kHz V– 4 5 +IN B 1.2 µV rms at 20 Hz to 20 kHz
10375- Figure 1. 8-Lead SOIC_N (R Suffix)
Low distortion: 0.00006% No phase reversal Rail-to-rail output Unity-gain stable APPLICATIONS Instrumentation Medical instruments Multipole filters Precision current measurement Photodiode amplifiers Sensors Audio GENERAL DESCRIPTION
The ADA4001-2 is a dual channel JFET amplifier that features With fast slew rate and great stability under capacitive loads, the low input voltage noise and current noise, input bias current, ADA4001-2 is a good fit for filter applications. With low input and rail-to-rail output. bias currents and noise, it offers a wide dynamic range for photodi- The combination of low noise and low input bias current makes ode amplifier circuits. Low noise and distortion, along with this amplifier especially suitable for high impedance sensor high output current and excel ent speed, make the ADA4001-2 amplification. With low noise and fast settling times, the a great choice for audio applications. ADA4001-2 provides good accuracy for medical instruments, The ADA4001-2 is specified over the −40°C to +125°C extended electronic measurement, and automated test equipment. Unlike industrial temperature range. many competitive amplifiers, the ADA4001-2 maintains fast The ADA4001-2 is available in an 8-lead narrow SOIC package. settling performance even with substantial capacitive loads, and, unlike many older JFET amplifiers, the ADA4001-2 does not suffer from output phase reversal when input voltages exceed the maximum common-mode voltage range.
Rev. C Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2012–2013 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications Pin Configuration General Description Revision History Specifications Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Applications Information Total Noise Including Source Resistors I-V Conversion Applications Photodiode Circuits Input Bias Current Noise Considerations Outline Dimensions Ordering Guide
