Datasheet ADA4001-2 (Analog Devices) - 2
DescriptionLow Noise, Low Input Bias Current, Rail-to-Rail Output, JFET Dual Op Amp
Pages / Page13 / 2 — ADA4001-2* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionC
File Format / SizePDF / 372 Kb
ADA4001-2* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS
ADA4001-2* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS
View a parametric search of comparable parts.
Technical Articles
• MS-2066: Low Noise Signal Conditioning for Sensor-Based
EVALUATION KITS
Circuits • EVAL-OPAMP-2 Evaluation Board
Tutorials
• MT-047: Op Amp Noise
DOCUMENTATION
• MT-048: Op Amp Noise Relationships: 1/f Noise, RMS
Application Notes
Noise, and Equivalent Noise Bandwidth • AN-202: An IC Amplifier User’s Guide to Decoupling, • MT-052: Op Amp Noise Figure: Don't Be Misled Grounding, and Making Things Go Right for a Change • AN-940: Low Noise Amplifier Selection Guide for Optimal
DESIGN RESOURCES
Noise Performance • ADA4001-2 Material Declaration
Data Sheet
• PCN-PDN Information • ADA4001-2: Low Noise, Low Input Bias Current, Rail-to- • Quality And Reliability Rail Output, JFET Dual Operational Amplifier Data Sheet • Symbols and Footprints
Technical Books
• Op Amp Applications Handbook, 2005
DISCUSSIONS
• Practical Design Techniques for Sensor Signal View all ADA4001-2 EngineerZone Discussions. Conditioning, 1999
SAMPLE AND BUY TOOLS AND SIMULATIONS
Visit the product page to see pricing options. • Analog Filter Wizard • Analog Photodiode Wizard
TECHNICAL SUPPORT
• ADA4001 SPICE Macro Model Submit a technical question or find your regional support number.
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified.
Document Outline Features Applications Pin Configuration General Description Revision History Specifications Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Applications Information Total Noise Including Source Resistors I-V Conversion Applications Photodiode Circuits Input Bias Current Noise Considerations Outline Dimensions Ordering Guide
