Datasheet ADA4800 (Analog Devices) - 10
DescriptionLow Power, High Speed CCD Buffer Amplifier
Pages / Page17 / 10 — ADA4800. TEST CIRCUIT. VISF. 0.1µF. ISF. 10µF. IDRV. 15V. 10kΩ. 249kΩ. …
RevisionA
File Format / SizePDF / 244 Kb
ADA4800. TEST CIRCUIT. VISF. 0.1µF. ISF. 10µF. IDRV. 15V. 10kΩ. 249kΩ. VCC. IBUFF. IAL. VEE. OUT. 10Ω. 1kΩ. 49.9Ω. .96m. .68m. 22pF. 7.5V
ADA4800 TEST CIRCUIT VISF 0.1µF ISF 10µF IDRV 15V 10kΩ 249kΩ VCC IBUFF IAL VEE OUT 10Ω 1kΩ 49.9Ω .96m .68m 22pF 7.5V
ADA4800 TEST CIRCUIT VISF A R 0.1µF A + A 3V ISF R 10µF IDRV 15V 1m 10kΩ 1m 5m 1 249kΩ 4 0 0. 1. 0. ISF VCC IDRV 6 5 4 IDRV ISF IBUFF ADA4800 +1 IAL 1 2 3 IN VEE OUT A A 10Ω 1kΩ 49.9Ω .96m .68m 22pF 2 4
6
7.5V 7.5V
02 2- 16 09 Figure 20. Typical Current Flow Rev. A | Page 9 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS BUFFER ELECTRICAL CHARACTERISTICS ACTIVE CURRENT LOAD ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUIT THEORY OF OPERATION SETTING ACTIVE LOAD CURRENT WITH PIN 6 (ISF) SETTING BANDWIDTH WITH PIN 4 (IDRV) APPLICATIONS INFORMATION OPEN SOURCE CCD OUTPUT BUFFER POWER SAVE MODE POWER SUPPLY BYPASSING POWER SEQUENCING OUTLINE DIMENSIONS ORDERING GUIDE
