Datasheet ADA4092-4 (Analog Devices) - 7
DescriptionMicropower, OVP, RRIO, Quad Op Amp
Pages / Page21 / 7 — ADA4092-4. ABSOLUTE MAXIMUM RATINGS. THERMAL RESISTANCE. Table 5. …
File Format / SizePDF / 664 Kb
ADA4092-4. ABSOLUTE MAXIMUM RATINGS. THERMAL RESISTANCE. Table 5. Parameter. Rating. Table 6. Thermal Resistance. Package Type. Unit
ADA4092-4 ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Table 5 Parameter Rating Table 6 Thermal Resistance Package Type Unit
link to page 17 link to page 17 link to page 17
ADA4092-4 ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Table 5. Parameter Rating
θJA is specified for the device soldered on a 4-layer JEDEC standard Supply Voltage 36 V printed circuit board (PCB) with zero airflow. Input Voltage Refer to the Input
Overvoltage Protection
Package Type θ θ Unit JA JC
section 14-Lead TSSOP (RU-14) 112 35 °C/W Differential Input Voltage ±V SY Input Current ±5 mA
ESD CAUTION
Output Short-Circuit Duration to GND Indefinite Storage Temperature Range −65°C to +150°C Operating Temperature Range −40°C to +125°C Junction Temperature Range −65°C to +150°C Lead Temperature (Soldering, 60 sec) 300°C Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Rev. B | Page 6 of 20 Document Outline Features Applications Pin Configuration General Description Revision History Specifications Electrical Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Theory of Operation Input Stage Output Stage Input Overvoltage Protection Comparator Operation Outline Dimensions Ordering Guide
