Datasheet ADA4691-2, ADA4691-4, ADA4692-2, ADA4692-4 (Analog Devices) - 8
DescriptionLow Power, 3.6 MHz, Low Noise, Rail-to-Rail Output, Quad Op Amp
Pages / Page20 / 8 — ADA4691-2/ADA4691-4/ADA4692-2/ADA4692-4. TYPICAL PERFORMANCE …
RevisionD
File Format / SizePDF / 716 Kb
ADA4691-2/ADA4691-4/ADA4692-2/ADA4692-4. TYPICAL PERFORMANCE CHARACTERISTICS. 350. 700. ADA4692-2. VSY = 2.7V. VSY = 5V
ADA4691-2/ADA4691-4/ADA4692-2/ADA4692-4 TYPICAL PERFORMANCE CHARACTERISTICS 350 700 ADA4692-2 VSY = 2.7V VSY = 5V
350 700 ADA4692-2 ADA4692-2 VSY = 2.7V VSY = 5V 300 TA = 25°C 600 TA = 25°C –0.3V ≤ VCM ≤ +1.6V –0.3V ≤ VCM ≤ +3.9V S SIGNIFIES CENTER S SIGNIFIES CENTER R 250 OF BIN R 500 OF BIN IE IE IF IF L L P 200 P 400 M M A A OF 150 OF 300 R R E E B B M M U 100 U 200 N N 50 100 0 0
6
–2.0 –1.6 –1.2 –0.8 –0.4 0 0.4 0.8 1.2 1.6 2.0
03 0
00 0- 0-
VOS (mV)
95
VOS (mV)
95 07 07 Figure 9. Input Offset Voltage Distribution Figure 12. Input Offset Voltage Distribution
30 30 ADA4692-2 ADA4692-2 VSY = ±1.35V VSY = ±2.5V –40°C < T –40°C < T 25 A < +125°C 25 A < +125°C SIGNIFIES CENTER SIGNIFIES CENTER OF BIN OF BIN RS RS IE 20 IE 20 IF IF L L P P AM 15 AM F 15 F R O R O BE 10 BE M 10 M NU NU 5 5 0 0
4 7
0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 2.0 2.2 2.4
00
00 0- 0-
TCVOS (µV/°C)
95
TCVOS (µV/°C)
95 07 07 Figure 10. Input Offset Voltage Drift Distribution Figure 13. Input Offset Voltage Drift Distribution
2.0 2.0 ADA4692-2 ADA4692-2 VSY = 2.7V VSY = 5V 1.5 T 1.5 A = 25°C TA = 25°C 1.0 1.0 0.5 0.5 V) V) (m 0 (m 0 OS OS V V –0.5 –0.5 –1.0 –1.0 –1.5 –1.5 –2.0 –2.0
5 8
–0.5 0 0.5 1.0 1.5 2.0 2.5
00
–0.5 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0
00 0- 0-
VCM (V)
95
VCM (V)
95 07 07 Figure 11. Input Offset Voltage vs. Common-Mode Voltage Figure 14. Input Offset Voltage vs. Common-Mode Voltage Rev. D | Page 8 of 20 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS—2.7 V OPERATION ELECTRICAL CHARACTERISTICS—5 V OPERATION ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS TYPICAL PERFORMANCE CHARACTERISTICS SHUTDOWN OPERATION INPUT PIN CHARACTERISTICS INPUT THRESHOLD OUTLINE DIMENSIONS ORDERING GUIDE
