Datasheet ADA4691-2, ADA4691-4, ADA4692-2, ADA4692-4 (Analog Devices) - 7
DescriptionLow Power, 3.6 MHz, Low Noise, Rail-to-Rail Output, Quad Op Amp
Pages / Page20 / 7 — ADA4691-2/ADA4691-4/ADA4692-2/ADA4692-4. PIN CONFIGURATIONS. BALL A1 …
RevisionD
File Format / SizePDF / 716 Kb
ADA4691-2/ADA4691-4/ADA4692-2/ADA4692-4. PIN CONFIGURATIONS. BALL A1 CORNER. OUT A 1. 8 V+. OUT B. OUT A. –IN A 2. ADA4692-2. 7 OUT B
ADA4691-2/ADA4691-4/ADA4692-2/ADA4692-4 PIN CONFIGURATIONS BALL A1 CORNER OUT A 1 8 V+ OUT B OUT A –IN A 2 ADA4692-2 7 OUT B
ADA4691-2/ADA4691-4/ADA4692-2/ADA4692-4 PIN CONFIGURATIONS BALL A1 CORNER OUT A 1 8 V+ OUT B V+ OUT A –IN A 2 ADA4692-2 7 OUT B TOP VIEW A1 A2 A3 +IN A 3 (Not to Scale) 6 –IN B
16 0
–IN B SD A/B –IN A V– 4 5 +IN B
0- 95 07
B1 B2 B3
Figure 6. 8-Lead, 2 mm × 2 mm LFCSP (CP-8-6)
+IN B V– +IN A C1 C2 C3 OUT A 1 8 V+ ADA4691-2 –IN 2 ADA4692-2 7 OUT B TOP VIEW
58 0
+IN 3 TOP VIEW 6 –IN B
1
(BALL SIDE DOWN)
0-
(Not to Scale)
00 95 0-
Not to Scale V– 4 5 +IN B
07 95 07 Figure 3. 9-Ball Wafer Level Chip Scale WLCSP (CB-9-3) Figure 7. 8-Lead SOIC_N (R-8)
A T U + OUT A 1 14 OUT D O V 0 1 9 –IN A 2 13 –IN D +IN A 3 ADA4692-4 12 +IN D –IN A 1 8 OUT B TOP VI V E I W E ADA4691-2 V+ 4 11 V– (Not (N to t Sc S a c le) +IN A 2 7 –IN B TOP VIEW +IN B 5 10 +IN C (Not to Scale) V– 3 6 +IN B –IN B 6 9 –IN C
9 05
OUT B 7 8 OUT C
0-
4 5
95 02 0
A B
07 0-
D D
795
S S
0 Figure 4. 10-Lead, 2 mm × 2 mm LFCSP (CP-10-11) Figure 8. 14-Lead TSSOP (RU-14)
A D A T T D NI U U NI O O 6 5 4 3 1 1 1 1 +IN A 1 12 +IN D V+ 2 11 V– ADA4691-4 +IN B 3 10 +IN C –IN B 4 9 –IN C 5 6 7 8 B B / D/ C T A C T U D U O D S S O TOP VIEW (Not to Scale)
60
NOTES
0 0-
1. IT IS RECOMMENDED THAT THE EXPOSED
95
PAD BE CONNCECTED TO V–.
07 Figure 5. 16-Lead, 3 mm × 3 mm LFCSP (CP-16-22) Rev. D | Page 7 of 20 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS—2.7 V OPERATION ELECTRICAL CHARACTERISTICS—5 V OPERATION ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS TYPICAL PERFORMANCE CHARACTERISTICS SHUTDOWN OPERATION INPUT PIN CHARACTERISTICS INPUT THRESHOLD OUTLINE DIMENSIONS ORDERING GUIDE
