Datasheet AD8622, AD8624 (Analog Devices)
Description | Low Power, Precision Rail-to-Rail Output Op Amp |
Pages / Page | 20 / 1 — Low Power, Precision. Rail-to-Rail Output Op Amp. Data Sheet. AD8622/. … |
Revision | D |
File Format / Size | PDF / 604 Kb |
Low Power, Precision. Rail-to-Rail Output Op Amp. Data Sheet. AD8622/. AD8624. FEATURES. PIN CONFIGURATIONS. Very low offset voltage
Low Power, Precision Rail-to-Rail Output Op Amp Data Sheet AD8622/ AD8624 FEATURES PIN CONFIGURATIONS Very low offset voltage OUT A 1 8 V+ 125 μV maximum –IN A 2 AD8622 7 OUT B Supply current: 215 μA/amp typical +IN A 3 TOP VIEW 6 –IN B
1 0
(Not to Scale)
0 7-
Input bias current: 200 pA maximum V– 4 5 +IN B
52 07
Low input offset voltage drift: 1.2 μV/°C maximum
Figure 1. 8-Lead Narrow-Body SOIC
Very low voltage noise: 11 nV/√Hz Operating temperature: −40°C to +125°C OUT A 1 8 V+ –IN A AD8622 2 7 OUT B Rail-to-rail output swing TOP VIEW +IN A 3 6 –IN B (Not to Scale)
2
Unity gain stable
00
V– 4 5 +IN B
7-
±2.5 V to ±15 V operation
752 0 Figure 2. 8-Lead MSOP
APPLICATIONS OUT A 1 14 OUT D Portable precision instrumentation –IN A 2 13 –IN D Laser diode control loops +IN A 3 AD8624 12 +IN D Strain gage amplifiers TOP VIEW V+ 4 11 V– Medical instrumentation (Not to Scale) +IN B 5 10 +IN C Thermocouple amplifiers –IN B 6 9 –IN C
67
OUT B 7 8 OUT C
07-
GENERAL DESCRIPTION
52 07 Figure 3. 14-Lead TSSOP The AD8622/AD8624 are dual and quad precision rail-to-rail
A D
output operational amplifiers with low supply currents of only
T T C U U C N O O N
350 μA/amplifier maximum over temperature and supply voltages.
6 5 4 3 1 1 1 1
The AD8622/AD8624 also has an input bias current cancellation circuitry that provides a very low input bias current over the full
–IN A 1 12 –IN D +IN A 2 AD8624 11 +IN D
operating temperature.
V+ 3 TOP VIEW 10 V– (Not to Scale)
With a typical offset voltage of only 10 μV, offset drift of 0.5 μV/°C,
+IN B 4 9 +IN C
and noise of only 0.2 μV p-p (0.1 Hz to 10 Hz), they are perfectly
5 6 7 8
suited for applications where large error sources cannot be
B B C C N T T N
tolerated. Many systems can take advantage of the low noise,
I U I – U – O O
dc precision, and rail-to-rail output swing provided by the
NOTES
68
1. NC = NO CONNECT.
0 AD8622/AD8624 to maximize the signal-to-noise ratio and 7-
2. IT IS RECOMMENDED THAT THE EXPOSED
52
PAD BE CONNECTED TO V–.
07 dynamic range for low power operation. The AD8622/AD8624 Figure 4. 16-Lead LFCSP are specified for the extended industrial temperature range of −40°C to +125°C. The AD8622 is available in lead-free 8-lead SOIC and MSOP packages, while the AD8624 is available in
Table 1. Low Power Op Amps
lead-free 14-lead TSSOP and 16-lead LFCSP packages.
Supply 40 V 36 V 12 V to 18 V 6 V
Single OP97 OP777 AD8663 OP1177 Dual OP297 OP727 AD8667 ADA4692-2 OP2177 Quad OP497 OP747 AD8669 ADA4692-4 OP4177
Rev. D Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2009–2013 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications General Description Pin Configurations Table of Contents Revision History Specifications Electrical Characteristics—±2.5 V Operation Electrical Characteristics—±15 V Operation Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Applications Information Input Protection Phase Reversal Micropower Instrumentation Amplifier Hall Sensor Signal Conditioning Simplified Schematic Outline Dimensions Ordering Guide
