DatasheetsDatasheet ADA4505-1, ADA4505-2, ADA4505-4 …
Datasheet ADA4505-1, ADA4505-2, ADA4505-4 (Analog Devices)
Description | 10µA, RRIO, Zero Input Crossover Distortion Single Op Amp |
Pages / Page | 24 / 1 — 10 μA, Rail-to-Rail I/O, Zero Input. Crossover Distortion Amplifiers. … |
Revision | E |
File Format / Size | PDF / 860 Kb |
10 μA, Rail-to-Rail I/O, Zero Input. Crossover Distortion Amplifiers. ADA4505-1/ADA4505-2/ADA4505-4. FEATURES
10 μA, Rail-to-Rail I/O, Zero Input Crossover Distortion Amplifiers ADA4505-1/ADA4505-2/ADA4505-4 FEATURES PIN CONFIGURATIONS PSRR: 100 dB minimum CMRR: 105 dB typical OUT 1 5 V+ ADA4505-1 OUT A 1 8 V+ Very low supply current: 10 μA per amplifier maximum V– 2 TOP VIEW –IN A 2 ADA4505-2 7 OUT B 1.8 V to 5 V single-supply or ±0.9 V to ±2.5 V dual-supply operation (Not to Scale) TOP VIEW +IN A 6 –IN B +IN
1
3 3 4 –IN
04
(Not to Scale)
00 0
Rail-to-rail input and output
6- 6-
V– 4 5 +IN B
41 741 07 0
3 mV offset voltage maximum
Figure 1. 5-Lead SOT-23 (RJ-5) Figure 2. 8-Lead MSOP (RM-8)
Very low input bias current: 0.5 pA typical BALL A1 APPLICATIONS INDICATOR BALL A1 CORNER Pressure and position sensors OUT V+ Remote security A1 A2 OUT B V+ OUT A Medical monitors V– NC A1 A2 A3 Battery-powered consumer equipment B1 B2 –IN B –IN A Hazard detectors +IN –IN B1 B3 C1 C2 GENERAL DESCRIPTION +IN B V– +IN A C1 C2 C3
The ADA4505-1/ADA4505-2/ADA4505-4 are single, dual, and
ADA4505-1
quad micropower amplifiers featuring rail-to-rail input and output
TOP VIEW
8
(BALL SIDE DOWN)
3
ADA4505-2
06 swings while operating from a single 1.8 V to 5 V power supply
Not to Scale
6- -00
TOP VIEW
41
NC = NO CONNECT
16
(BALL SIDE DOWN)
07 74 or from dual ±0.9 V to ±2.5 V power supplies. 0 Employing a new circuit technology, these low cost amplifiers Figure 3. 6-Ball WLCSP (CB-6-7) Figure 4. 8-Ball WLCSP (CB-8-2) offer zero input crossover distortion (excellent PSRR and CMRR
BALL A1 INDICATOR
performance) and very low bias current, while operating with a
OUT D OUT A –IN A
supply current of less than 10 μA per amplifier.
A1 A2 A3
This combination of features makes the ADA4505-x amplifiers
–IN D V– +IN A B1 B2 B3
ideal choices for battery-powered applications because they
+IN D +IN B
minimize errors due to power supply voltage variations over the
OUT A 1 14 OUT D C1 C3
lifetime of the battery and maintain high CMRR even for a rail-
–IN A 2 13 –IN D +IN C V+ –IN B ADA4505-4
to-rail op amp.
+IN A 3 12 +IN D D1 D2 D3 TOP VIEW V+ 4 11 V– –IN C OUT C OUT B
Remote battery-powered sensors, handheld instrumentation
(Not to Scale) E1 E2 E3 +IN B 5 10 +IN C
and consumer equipment, hazard detectors (for example, smoke,
–IN B 6 9 –IN C ADA4505-4
fire, and gas), and patient monitors can benefit from the features 5
TOP VIEW
61 00
OUT B 7 8 OUT C
0 6- of the ADA4505-x amplifiers. 6-
(BALL SIDE DOWN)
41
Not to Scale
41 07 07 The ADA4505-x family is specified for both the industrial Figure 5. 14-Lead TSSOP (RU-14) Figure 6. 14-Ball WLCSP (CB-14-1) temperature range (−40°C to +85°C) and the extended industrial temperature range (−40°C to +125°C). The ADA4505-1 single amplifier is available in a tiny 5-lead SOT-23 and a 6-ball WLCSP. The ADA4505-2 dual amplifier is available in a standard 8-lead MSOP and a 8-ball WLCSP. The ADA4505-4 quad amplifier is available in a 14-lead TSSOP and a 14-ball WLCSP. The ADA4505-x family is a member of a growing series of zero crossover op amps offered by Analog Devices, Inc., including the AD8505/AD8506/AD8508, which also operate from a single 1.8 V to 5 V power supply or from dual ±0.9 V to ±2.5 V power supplies.
Rev. D Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©2008–2010 Analog Devices, Inc. All rights reserved.
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS—1.8 V OPERATION ELECTRICAL CHARACTERISTICS—5 V OPERATION ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION PULSE OXIMETER CURRENT SOURCE FOUR-POLE, LOW-PASS BUTTERWORTH FILTER FOR GLUCOSE MONITOR OUTLINE DIMENSIONS ORDERING GUIDE NOTES NOTES NOTES
