Datasheet ADA4505-1, ADA4505-2, ADA4505-4 (Analog Devices) - 5
Description10µA, RRIO, Zero Input Crossover Distortion Single Op Amp
Pages / Page24 / 5 — ADA4505-1/ADA4505-2/ADA4505-4. ABSOLUTE MAXIMUM RATINGS. THERMAL …
RevisionE
File Format / SizePDF / 860 Kb
ADA4505-1/ADA4505-2/ADA4505-4. ABSOLUTE MAXIMUM RATINGS. THERMAL RESISTANCE. Table 3. Parameter Rating. Table 4. Package Type
ADA4505-1/ADA4505-2/ADA4505-4 ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Table 3 Parameter Rating Table 4 Package Type
link to page 5
ADA4505-1/ADA4505-2/ADA4505-4 ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Table 3. Parameter Rating
θJA is specified for the worst-case conditions, that is, a device Supply Voltage 5.5 V soldered in a circuit board for surface-mount packages with its Input Voltage ±VSY ± 0.1 V exposed paddle soldered to a pad (if applicable). Simulated Input Current1 ±10 mA thermal numbers on a 4-layer (2S/2P) JEDEC standard thermal Differential Input Voltage2 ±VSY test board, unless otherwise specified. Output Short-Circuit Duration to GND Indefinite
Table 4.
Storage Temperature Range −65°C to +150°C
Package Type θ
Operating Temperature Range −40°C to +125°C
JA θJC Unit
Junction Temperature Range −65°C to +150°C 5-Lead SOT-23 (RJ-5) 190 92 °C/W Lead Temperature (Soldering, 60 sec) 300°C 6-Ball WLCSP (CB-6-7) 105 2.6 °C/W 8-Lead MSOP (RM-8) 142 45 °C/W 1 Input pins have clamp diodes to the supply pins. Limit input current to 10 mA 8-Ball WLCSP (CB-8-2) 82 N/A °C/W or less whenever the input signal exceeds the power supply rail by 0.1 V. 2 14-Lead TSSOP (RU-14) 112 35 °C/W Differential input voltage is limited to 5 V or the supply voltage, whichever is less. 14-Ball WLCSP (CB-14-1) 64 N/A °C/W Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any
ESD CAUTION
other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Rev. D | Page 5 of 24 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS—1.8 V OPERATION ELECTRICAL CHARACTERISTICS—5 V OPERATION ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION PULSE OXIMETER CURRENT SOURCE FOUR-POLE, LOW-PASS BUTTERWORTH FILTER FOR GLUCOSE MONITOR OUTLINE DIMENSIONS ORDERING GUIDE NOTES NOTES NOTES
