Datasheet ADA4859-3 (Analog Devices) - 2
DescriptionSingle-Supply, Fixed G = 2, High Speed, Video Amplifier with Charge Pump
Pages / Page17 / 2 — ADA4859-3* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionA
File Format / SizePDF / 390 Kb
ADA4859-3* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS. Tutorials
ADA4859-3* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS Tutorials
View a parametric search of comparable parts.
Tutorials
• MT-032: Ideal Voltage Feedback (VFB) Op Amp
EVALUATION KITS
• MT-033: Voltage Feedback Op Amp Gain and Bandwidth • ADA4859-3 Evaluation Board • MT-047: Op Amp Noise • MT-048: Op Amp Noise Relationships: 1/f Noise, RMS
DOCUMENTATION
Noise, and Equivalent Noise Bandwidth
Application Notes
• MT-049: Op Amp Total Output Noise Calculations for • AN-402: Replacing Output Clamping Op Amps with Input Single-Pole System Clamping Amps • MT-050: Op Amp Total Output Noise Calculations for • AN-417: Fast Rail-to-Rail Operational Amplifiers Ease Second-Order System Design Constraints in Low Voltage High Speed Systems • MT-052: Op Amp Noise Figure: Don't Be Misled • AN-581: Biasing and Decoupling Op Amps in Single • MT-053: Op Amp Distortion: HD, THD, THD + N, IMD, Supply Applications SFDR, MTPR
Data Sheet
• MT-056: High Speed Voltage Feedback Op Amps • ADA4859-3: Single-Supply, Fixed G=2, High Speed, Video • MT-058: Effects of Feedback Capacitance on VFB and CFB Amplifier with Charge Pump Data Sheet Op Amps
User Guides
• MT-059: Compensating for the Effects of Input • UG-140: Universal Evaluation Board for Triple, High Speed Capacitance on VFB and CFB Op Amps Used in Current-to- Op Amps with Charge Pump Offered in 16-Lead, 4 mm × 4 Voltage Converters mm LFCSP Packages • MT-060: Choosing Between Voltage Feedback and Current Feedback Op Amps
TOOLS AND SIMULATIONS DESIGN RESOURCES
• Power Dissipation vs Die Temp • VRMS/dBm/dBu/dBV calculators • ADA4859-3 Material Declaration • PCN-PDN Information • Quality And Reliability • Symbols and Footprints
DISCUSSIONS
View all ADA4859-3 EngineerZone Discussions.
SAMPLE AND BUY
Visit the product page to see pricing options.
TECHNICAL SUPPORT
Submit a technical question or find your regional support number.
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified.
Document Outline Features Applications General Description Connection Diagram Table of Contents Revision History Specifications Absolute Maximum Ratings Maximum Power Dissipation ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Overview Charge Pump Operation Applications Information Using the ADA4859-3 in Gains Equal to +1, −1 Unity-Gain Operation Option 1 Option 2 Inverting Unity-Gain Operation Video Line Driver Power-Down Layout Considerations Power Supply Bypassing Outline Dimensions Ordering Guide
