Datasheet ADA4859-3 (Analog Devices) - 6
DescriptionSingle-Supply, Fixed G = 2, High Speed, Video Amplifier with Charge Pump
Pages / Page17 / 6 — Data Sheet. ADA4859-3. ABSOLUTE MAXIMUM RATINGS. MAXIMUM POWER …
RevisionA
File Format / SizePDF / 390 Kb
Data Sheet. ADA4859-3. ABSOLUTE MAXIMUM RATINGS. MAXIMUM POWER DISSIPATION. Table 3. Parameter. Rating. 2.5. 2.0. IO T. 1.5. ISSI D. ER W. 1.0
Data Sheet ADA4859-3 ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION Table 3 Parameter Rating 2.5 2.0 IO T 1.5 ISSI D ER W 1.0
link to page 6 link to page 6 link to page 6
Data Sheet ADA4859-3 ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION Table 3. Parameter Rating
The maximum power that can be safely dissipated by the Supply Voltage 6 V ADA4859-3 is limited by the associated rise in junction Internal Power Dissipation1 temperature. The maximum safe junction temperature 16-Lead LFCSP See Figure 2 for plastic encapsulated devices is determined by the glass Input Voltage (Common-Mode) (−V − 0.2 V) to (+V − 1.8 V) transition temperature of the plastic, approximately 150°C. S S Differential Input Voltage ±V Temporarily exceeding this limit may cause a shift in parametric S Output Short-Circuit Duration Observe power derating curves performance due to a change in the stresses exerted on the die Storage Temperature Range −65°C to +125°C by the package. Exceeding a junction temperature of 175°C for Operating Temperature Range −40°C to +105°C an extended period can result in device failure. Lead Temperature 300°C To ensure proper operation, it is necessary to observe the (Soldering, 10 sec) maximum power derating curves in Figure 2. 1 Specification is for device in free air.
2.5
Stresses above those listed under Absolute Maximum Ratings
may cause permanent damage to the device. This is a stress
(W 2.0 N
rating only; functional operation of the device at these or any
IO T
other conditions above those indicated in the operational
PA 1.5
section of this specification is not implied. Exposure to absolute
ISSI D
maximum rating conditions for extended periods may affect
ER W
device reliability.
1.0 M PO MU XI 0.5 MA 0 –40 –20 0 20 40 60 80 100
002
AMBIENT TEMPERATURE (°C)
07715- Figure 2. Maximum Power Dissipation vs. Ambient Temperature
ESD CAUTION
Rev. A | Page 5 of 16 Document Outline Features Applications General Description Connection Diagram Table of Contents Revision History Specifications Absolute Maximum Ratings Maximum Power Dissipation ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Overview Charge Pump Operation Applications Information Using the ADA4859-3 in Gains Equal to +1, −1 Unity-Gain Operation Option 1 Option 2 Inverting Unity-Gain Operation Video Line Driver Power-Down Layout Considerations Power Supply Bypassing Outline Dimensions Ordering Guide
